<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Load and write blocks of 512 direct to sd card M5Core2]]></title><description><![CDATA[<p dir="auto">Is it possible to read/write blocks of 512 bytes direct to the sd card?<br />
This without using the M5Stack filesystem.<br />
I know with the SDFat.h library it is possible,  there are commands for readBlock(block,buffer) and writeBlock(block, buffer), and buffer is defined as<br />
byte buffer[512].<br />
But I get not compiled this library under my Core2.<br />
Appreciatie any help with this.</p>
<p dir="auto">Cheers,<br />
Jan</p>
]]></description><link>https://community.m5stack.com/topic/3288/load-and-write-blocks-of-512-direct-to-sd-card-m5core2</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 15:36:42 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3288.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 18 May 2021 18:27:37 GMT</pubDate><ttl>60</ttl></channel></rss>
