<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[My M5Stack Core2 ESP32 IoT Development Kit for AWS out of order after the first power off]]></title><description><![CDATA[<p dir="auto">Hi<br />
I have just received my M5Stack Core2 ESP32.<br />
I powered it up by connecting it to the USB port of my PC and it started up without any problem: screen display, led lighting etc.<br />
I stopped it by pressing the power off button for a few seconds.<br />
Since then, I can't restart it. The screen remains black. No led lights up. Does anyone have an idea? Maybe is it definitively out of order ?</p>
]]></description><link>https://community.m5stack.com/topic/3309/my-m5stack-core2-esp32-iot-development-kit-for-aws-out-of-order-after-the-first-power-off</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 02:29:35 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3309.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 24 May 2021 15:21:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to My M5Stack Core2 ESP32 IoT Development Kit for AWS out of order after the first power off on Sat, 26 Oct 2024 03:59:02 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/technochoa" aria-label="Profile: technochoa">@<bdi>technochoa</bdi></a></p>
<p dir="auto">for M5CoreS3 there is an UIFlow2.0 firmware <code>v2.1.6-hotfix</code> available which works for me.</p>
<p dir="auto">BTW: there is also a <code>v2.1.6-hotfix</code> available for M5Core2 and M5Core.</p>
]]></description><link>https://community.m5stack.com/post/26861</link><guid isPermaLink="true">https://community.m5stack.com/post/26861</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sat, 26 Oct 2024 03:59:02 GMT</pubDate></item><item><title><![CDATA[Reply to My M5Stack Core2 ESP32 IoT Development Kit for AWS out of order after the first power off on Sat, 26 Oct 2024 01:57:29 GMT]]></title><description><![CDATA[<p dir="auto">Guys I was having the same issue but with a CoreS3 a clicking noise and the touch and the screen were gone, but when I got it back to the original firmware worked fine, then I supposed was the firmware that I was burning for it, the latest but I guess they did not tested on all the controllers, when back again to burn the firmware for IUFlow2 and went down one version and that solve all the problems, do not put the latest firmware on it.</p>
]]></description><link>https://community.m5stack.com/post/26860</link><guid isPermaLink="true">https://community.m5stack.com/post/26860</guid><dc:creator><![CDATA[technochoa]]></dc:creator><pubDate>Sat, 26 Oct 2024 01:57:29 GMT</pubDate></item><item><title><![CDATA[Reply to My M5Stack Core2 ESP32 IoT Development Kit for AWS out of order after the first power off on Sun, 20 Oct 2024 06:39:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/susbhaga" aria-label="Profile: susbhaga">@<bdi>susbhaga</bdi></a> have you tried charging the battery and then erasing and returning UIFlow2?</p>
]]></description><link>https://community.m5stack.com/post/26796</link><guid isPermaLink="true">https://community.m5stack.com/post/26796</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 20 Oct 2024 06:39:54 GMT</pubDate></item><item><title><![CDATA[Reply to My M5Stack Core2 ESP32 IoT Development Kit for AWS out of order after the first power off on Sun, 20 Oct 2024 05:07:36 GMT]]></title><description><![CDATA[<p dir="auto">Hi, i''m facing the same issue with the Core2 ESP32 Dev kit. it's not switching on the second time, and i hear that constant clicking sound. was anyone able to find a solution to this ?</p>
]]></description><link>https://community.m5stack.com/post/26794</link><guid isPermaLink="true">https://community.m5stack.com/post/26794</guid><dc:creator><![CDATA[susbhaga]]></dc:creator><pubDate>Sun, 20 Oct 2024 05:07:36 GMT</pubDate></item><item><title><![CDATA[Reply to My M5Stack Core2 ESP32 IoT Development Kit for AWS out of order after the first power off on Sun, 30 Oct 2022 13:58:26 GMT]]></title><description><![CDATA[<p dir="auto">What revision are you using as my AWS works fine. Have you tried using M5Burner to erase and rewrite the firmware</p>
]]></description><link>https://community.m5stack.com/post/19161</link><guid isPermaLink="true">https://community.m5stack.com/post/19161</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 30 Oct 2022 13:58:26 GMT</pubDate></item><item><title><![CDATA[Reply to My M5Stack Core2 ESP32 IoT Development Kit for AWS out of order after the first power off on Sat, 29 Oct 2022 05:05:21 GMT]]></title><description><![CDATA[<p dir="auto">I am having the exact same problem.  In addition to the black screen,  I also hear a constant clicking.  Now, my computer won't recognize device and the USB port. Still looking for a solution so i don't have to return it, for the 2nd time.</p>
]]></description><link>https://community.m5stack.com/post/19148</link><guid isPermaLink="true">https://community.m5stack.com/post/19148</guid><dc:creator><![CDATA[nerdmeeting]]></dc:creator><pubDate>Sat, 29 Oct 2022 05:05:21 GMT</pubDate></item><item><title><![CDATA[Reply to My M5Stack Core2 ESP32 IoT Development Kit for AWS out of order after the first power off on Fri, 28 May 2021 01:49:40 GMT]]></title><description><![CDATA[<p dir="auto">even connect to the USB still can't turn on the device?</p>
<p dir="auto">does the power LED(green) is the lighting? if doesn't,  pls contact the store.</p>
]]></description><link>https://community.m5stack.com/post/13907</link><guid isPermaLink="true">https://community.m5stack.com/post/13907</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Fri, 28 May 2021 01:49:40 GMT</pubDate></item></channel></rss>
