<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[RFID Unit issues]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I'm using RFID Unid with RFID cards and I experience problems.<br />
I can read UID, if card is on, read and write blocks however I need to go out and put the card back between each command otherwise it doesn't work.<br />
For exemple, if I send 2 consecutive isCardOn(), only the first one returns True, the second one and more return False.</p>
<p dir="auto">Is there anyone who has experienced the same problem?.</p>
<p dir="auto">Thanks</p>
]]></description><link>https://community.m5stack.com/topic/3318/rfid-unit-issues</link><generator>RSS for Node</generator><lastBuildDate>Thu, 07 May 2026 23:38:45 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3318.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 27 May 2021 03:49:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to RFID Unit issues on Wed, 09 Jun 2021 02:17:11 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I found a solution.<br />
I have to limit the I2C frequency to 100,000kbps otherwise it won't work properly.<br />
This is strange because a frequency of 400,000 kbps works for all other devices and the MFRC522 should work fine at that frequency.</p>
<p dir="auto">If anyone has any idea on this limitation, I am very interested.</p>
<p dir="auto">Thank you</p>
]]></description><link>https://community.m5stack.com/post/14047</link><guid isPermaLink="true">https://community.m5stack.com/post/14047</guid><dc:creator><![CDATA[Patrice]]></dc:creator><pubDate>Wed, 09 Jun 2021 02:17:11 GMT</pubDate></item><item><title><![CDATA[Reply to RFID Unit issues on Tue, 01 Jun 2021 02:04:27 GMT]]></title><description><![CDATA[<p dir="auto">Hi,<br />
Thank you for your reply.<br />
Yes, I tried with 3 other cards and it's the same.<br />
I have done more tests and it is very surprising.</p>
<p dir="auto">The RFID card is located on the top of the device.<br />
In an infinite loop, I just continuously check isCardOn () and measure the time between each detection.<br />
Without moving the card of the device, I measure 11 detections continuously with 1.2 seconds between each detection and nearly 6 seconds between the 11th and 12th then another 11 measurements with 1.2 seconds .....</p>
<p dir="auto">If I remove the card and put it on quickly, I can measure times less than 1 second.</p>
]]></description><link>https://community.m5stack.com/post/13970</link><guid isPermaLink="true">https://community.m5stack.com/post/13970</guid><dc:creator><![CDATA[Patrice]]></dc:creator><pubDate>Tue, 01 Jun 2021 02:04:27 GMT</pubDate></item><item><title><![CDATA[Reply to RFID Unit issues on Thu, 27 May 2021 11:40:48 GMT]]></title><description><![CDATA[<p dir="auto">that is so weird.    did you have another card for the test?    or all card has same situation?</p>
]]></description><link>https://community.m5stack.com/post/13901</link><guid isPermaLink="true">https://community.m5stack.com/post/13901</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Thu, 27 May 2021 11:40:48 GMT</pubDate></item></channel></rss>
