<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[m5stack unitv2 AI Camera - getting started]]></title><description><![CDATA[<p dir="auto">Just arrived. When I plug into a  Windows 10 machine I see a device called USB 10/100 LAN with the yellow warning triangle. So no driver. Where do I find the driver, please?</p>
<p dir="auto">Also, by default should I be able to access the device via WiFI on the SSID M5UV2_XXXX ? I see no such SSID being broadcast.</p>
<p dir="auto">Thanks!</p>
<p dir="auto">Pat</p>
]]></description><link>https://community.m5stack.com/topic/3320/m5stack-unitv2-ai-camera-getting-started</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 00:14:00 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3320.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 27 May 2021 09:37:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to m5stack unitv2 AI Camera - getting started on Sat, 19 Jun 2021 13:02:19 GMT]]></title><description><![CDATA[<p dir="auto">Having a similar issue, I've got into the web server, but the AP isn't starting, I can't even find the AP ID or even tell if it's started?</p>
]]></description><link>https://community.m5stack.com/post/14150</link><guid isPermaLink="true">https://community.m5stack.com/post/14150</guid><dc:creator><![CDATA[Asmodev]]></dc:creator><pubDate>Sat, 19 Jun 2021 13:02:19 GMT</pubDate></item><item><title><![CDATA[Reply to m5stack unitv2 AI Camera - getting started on Wed, 02 Jun 2021 11:18:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nechry" aria-label="Profile: nechry">@<bdi>nechry</bdi></a> not yet.   sorry.  when we update it , we will public a post to the community.</p>
]]></description><link>https://community.m5stack.com/post/13981</link><guid isPermaLink="true">https://community.m5stack.com/post/13981</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Wed, 02 Jun 2021 11:18:42 GMT</pubDate></item><item><title><![CDATA[Reply to m5stack unitv2 AI Camera - getting started on Wed, 02 Jun 2021 05:21:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a> ok thank for the update. do you have a expected release date for the next firmware with wifi?</p>
]]></description><link>https://community.m5stack.com/post/13977</link><guid isPermaLink="true">https://community.m5stack.com/post/13977</guid><dc:creator><![CDATA[nechry]]></dc:creator><pubDate>Wed, 02 Jun 2021 05:21:40 GMT</pubDate></item><item><title><![CDATA[Reply to m5stack unitv2 AI Camera - getting started on Tue, 01 Jun 2021 01:54:14 GMT]]></title><description><![CDATA[<p dir="auto">we debug these issues now.   we will release the new firmware update to fix it later.</p>
]]></description><link>https://community.m5stack.com/post/13967</link><guid isPermaLink="true">https://community.m5stack.com/post/13967</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Tue, 01 Jun 2021 01:54:14 GMT</pubDate></item><item><title><![CDATA[Reply to m5stack unitv2 AI Camera - getting started on Mon, 31 May 2021 11:02:31 GMT]]></title><description><![CDATA[<p dir="auto">Hi allk. Same for me no Ap is broadcasted. Can ssh to the unit via 10/100 USB-LAN, but sudo is not working so even when finding the configuration for WLAN I think its not possible to change.</p>
]]></description><link>https://community.m5stack.com/post/13963</link><guid isPermaLink="true">https://community.m5stack.com/post/13963</guid><dc:creator><![CDATA[albert8413]]></dc:creator><pubDate>Mon, 31 May 2021 11:02:31 GMT</pubDate></item><item><title><![CDATA[Reply to m5stack unitv2 AI Camera - getting started on Fri, 28 May 2021 14:19:00 GMT]]></title><description><![CDATA[<p dir="auto">Maybe for Mac os this is the driver <a href="http://www.corechip-sz.com/endownload.asp" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.corechip-sz.com/endownload.asp</a></p>
<p dir="auto">"SR9900 MacOS Big Sur Driver"</p>
<p dir="auto">Its not available to download for normal user.</p>
<p dir="auto">Thanks. Alex</p>
]]></description><link>https://community.m5stack.com/post/13933</link><guid isPermaLink="true">https://community.m5stack.com/post/13933</guid><dc:creator><![CDATA[itsover9000]]></dc:creator><pubDate>Fri, 28 May 2021 14:19:00 GMT</pubDate></item><item><title><![CDATA[Reply to m5stack unitv2 AI Camera - getting started on Fri, 28 May 2021 09:55:35 GMT]]></title><description><![CDATA[<p dir="auto">I can’t see the ssid from my side. anything to active on the unit?<br />
any chance to get the driver for macOSX?</p>
]]></description><link>https://community.m5stack.com/post/13929</link><guid isPermaLink="true">https://community.m5stack.com/post/13929</guid><dc:creator><![CDATA[nechry]]></dc:creator><pubDate>Fri, 28 May 2021 09:55:35 GMT</pubDate></item><item><title><![CDATA[Reply to m5stack unitv2 AI Camera - getting started on Fri, 28 May 2021 08:18:43 GMT]]></title><description><![CDATA[<p dir="auto">Same issue, im running a mac so i think hotspot connectivity is my only choice and im having same issue the wifi network is not available to connect ?</p>
]]></description><link>https://community.m5stack.com/post/13928</link><guid isPermaLink="true">https://community.m5stack.com/post/13928</guid><dc:creator><![CDATA[itsover9000]]></dc:creator><pubDate>Fri, 28 May 2021 08:18:43 GMT</pubDate></item><item><title><![CDATA[Reply to m5stack unitv2 AI Camera - getting started on Thu, 27 May 2021 11:57:39 GMT]]></title><description><![CDATA[<p dir="auto">same issue for me, the device didn’t broadcast any WiFi. I can only connect via the USB ethernet Lan.</p>
<p dir="auto">Also, Is there a way to use the USB network adapter on OSX system?</p>
]]></description><link>https://community.m5stack.com/post/13920</link><guid isPermaLink="true">https://community.m5stack.com/post/13920</guid><dc:creator><![CDATA[nechry]]></dc:creator><pubDate>Thu, 27 May 2021 11:57:39 GMT</pubDate></item><item><title><![CDATA[Reply to m5stack unitv2 AI Camera - getting started on Thu, 27 May 2021 11:28:09 GMT]]></title><description><![CDATA[<p dir="auto">check the tutorial you will get the driver</p>
<p dir="auto"><a href="https://docs.m5stack.com/en/quick_start/unitv2/base_functions" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/en/quick_start/unitv2/base_functions</a></p>
]]></description><link>https://community.m5stack.com/post/13898</link><guid isPermaLink="true">https://community.m5stack.com/post/13898</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Thu, 27 May 2021 11:28:09 GMT</pubDate></item></channel></rss>
