<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[GPS Module. M5Stack Gray]]></title><description><![CDATA[<p dir="auto">Ola possuo um modulo de GPS, porem para minha aplicação necessito converter o dado recebido pelo modo em um numero INT ou FLOAT, porem ao tentar utilizar a conversão o sistema relata um erro. Alguém possui uma solução para este problema de conversão?</p>
<p dir="auto">Brazil</p>
<p dir="auto">Hello I have a GPS module, however for my application I need to convert the data given by the mode into an INT or FLOAT number, however I try a conversion in the system the same reports an error. Does anyone have a solution to this conversion problem?</p>
]]></description><link>https://community.m5stack.com/topic/3339/gps-module-m5stack-gray</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 09:32:20 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3339.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 01 Jun 2021 20:29:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to GPS Module. M5Stack Gray on Wed, 02 Jun 2021 11:27:29 GMT]]></title><description><![CDATA[<p dir="auto">ah. that seems like a program grammar issues. you need confirm the str don't included any "Special characters". before you use function to conversion it</p>
]]></description><link>https://community.m5stack.com/post/13983</link><guid isPermaLink="true">https://community.m5stack.com/post/13983</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Wed, 02 Jun 2021 11:27:29 GMT</pubDate></item></channel></rss>
