<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Core2 Proto Perf Board]]></title><description><![CDATA[<p dir="auto">Is there a stackable proto board for the Core2 similar to the one for the original M5Stack?  The only one I've been able to find doesn't have the correct pinouts labeled.</p>
<p dir="auto">Though mis-labeled, will the M001 board match up with the Core2 dimensions?</p>
]]></description><link>https://community.m5stack.com/topic/3404/core2-proto-perf-board</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 01:00:31 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3404.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 27 Jun 2021 13:27:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Core2 Proto Perf Board on Thu, 24 Mar 2022 12:47:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> I found the M024 M-BUS Connection proto board.  It looks like the bus is available on two rows.  I think this is the thing to use for connecting to the bus.</p>
<p dir="auto"><a href="https://shop.m5stack.com/products/bus-module" target="_blank" rel="noopener noreferrer nofollow ugc">https://shop.m5stack.com/products/bus-module</a></p>
]]></description><link>https://community.m5stack.com/post/17013</link><guid isPermaLink="true">https://community.m5stack.com/post/17013</guid><dc:creator><![CDATA[stanely]]></dc:creator><pubDate>Thu, 24 Mar 2022 12:47:20 GMT</pubDate></item><item><title><![CDATA[Reply to Core2 Proto Perf Board on Sat, 05 Mar 2022 23:01:03 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/stanely" aria-label="Profile: stanely">@<bdi>stanely</bdi></a></p>
<p dir="auto">sorry about that. I am used to solder SMD components by hand (with the help of a magnifier glass) so for me soldering to the surface mount headers isn't really an issue.</p>
<p dir="auto">I use one proto board with the battery connectors broken out so I can measure power consumption and another proto board where I have TX, RX, GPIO0, EN and GND broken out so I can use it to flash one of my cores where I accidentally killed the onboard USB UART chip.</p>
]]></description><link>https://community.m5stack.com/post/16836</link><guid isPermaLink="true">https://community.m5stack.com/post/16836</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sat, 05 Mar 2022 23:01:03 GMT</pubDate></item><item><title><![CDATA[Reply to Core2 Proto Perf Board on Sat, 05 Mar 2022 19:11:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> I got some of these proto boards model M001, and it was a real mistake. They don't break out any bus signals, so you have to solder tack on tiny wires to the inaccessible surface-mount headers.  Ugh.  This is a poorly-designed and hard to use proto board.  All they had to do is add a couple through-hole rows with the bus signals.  I have yet to find a single example of someone actually using this proto board to build something useful.</p>
]]></description><link>https://community.m5stack.com/post/16834</link><guid isPermaLink="true">https://community.m5stack.com/post/16834</guid><dc:creator><![CDATA[stanely]]></dc:creator><pubDate>Sat, 05 Mar 2022 19:11:21 GMT</pubDate></item><item><title><![CDATA[Reply to Core2 Proto Perf Board on Sun, 27 Jun 2021 15:00:47 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/stanely" aria-label="Profile: stanely">@<bdi>stanely</bdi></a></p>
<p dir="auto">I don't know of a Proto board specifically for M5Core2.</p>
<p dir="auto">And yes, the M001 Proto board works fine with the M5Core2 (mechanically and electrically). The only 'issue' is the incorrect labeling of some pins.</p>
<p dir="auto">Maybe this <a href="https://www.gwendesign.ch/kb/m5stack/m5core2/#m5core2-bus-and-gpios-compared-to-m5stack" target="_blank" rel="noopener noreferrer nofollow ugc">comparison sheet</a> I've put together a while ago can help.</p>
]]></description><link>https://community.m5stack.com/post/14236</link><guid isPermaLink="true">https://community.m5stack.com/post/14236</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 27 Jun 2021 15:00:47 GMT</pubDate></item></channel></rss>
