<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Use rainmaker with m5stack-core-esp32]]></title><description><![CDATA[<p dir="auto">Hi everyone, I'm trying to use rainmaker with my <strong>m5stack-core-esp32</strong> with Arduino framework.<br />
When I build the code, this failed for flash memory.</p>
<pre><code class="language-sh">CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/m5stack-core-esp32.html
PLATFORM: Espressif 32 (3.3.0+sha.ab75429) &gt; M5Stack Core ESP32
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
DEBUG: Current (esp-prog) External (esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
PACKAGES:
 - framework-arduinoespressif32 0.0.0+sha.c37557c
 - tool-esptoolpy 1.30100.210531 (3.1.0)
 - toolchain-xtensa32 2.80400.210211 (8.4.0)
LDF: Library Dependency Finder -&gt; http://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 30 compatible libraries
Scanning dependencies...
Dependency Graph
|-- &lt;ESP RainMaker&gt; 2.0.0
|-- &lt;WiFi&gt; 2.0.0
|-- &lt;WiFiProv&gt; 2.0.0
|   |-- &lt;SimpleBLE&gt; 2.0.0
Building in release mode
Retrieving maximum program size .pio\build\m5stack-core-esp32\firmware.elf
Checking size .pio\build\m5stack-core-esp32\firmware.elf
Advanced Memory Usage is available via "PlatformIO Home &gt; Project Inspect"
RAM:   [=         ]  13.1% (used 42936 bytes from 327680 bytes)
Error: The program size (1716093 bytes) is greater than maximum allowed (1310720 bytes)
Flash: [====*** [checkprogsize] Explicit exit, status 1
======]  130.9% (used 1716093 bytes from 1310720 bytes)
<p dir="auto">Anybody knows how to load or use rainmaker with <strong>m5stack core esp32</strong> (not CORE2) . Maybe traying to reduce other libs or use <strong>espidf</strong> instead of Arduino.<br />
Thanks.</p>
]]></description><link>https://community.m5stack.com/topic/3433/use-rainmaker-with-m5stack-core-esp32</link><generator>RSS for Node</generator><lastBuildDate>Fri, 01 May 2026 07:13:19 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3433.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 04 Jul 2021 17:23:09 GMT</pubDate><ttl>60</ttl></channel></rss>
