<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Core Ink]]></title><description><![CDATA[<p dir="auto">Hi,<br />
Appreciate any help on this... I'm trying to switch a relay on/off on my Core Ink, and it's working fine while the Core Ink is connected on USB, but as soon as I unplug, it stops.  Presumably this is because I only get 5V supply when on USB?  How can I drive a relay from the battery on board the Core Ink?  is there any 3V or 5V output from any port that should work when on battery?</p>
<p dir="auto">Thanks,<br />
Anthony.</p>
]]></description><link>https://community.m5stack.com/topic/3454/core-ink</link><generator>RSS for Node</generator><lastBuildDate>Wed, 13 May 2026 04:15:18 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3454.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 14 Jul 2021 12:31:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Core Ink on Thu, 15 Jul 2021 18:43:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a><br />
thanks Felix for your help I now have it working...  something was going wrong between moving from USB to battery.</p>
]]></description><link>https://community.m5stack.com/post/14416</link><guid isPermaLink="true">https://community.m5stack.com/post/14416</guid><dc:creator><![CDATA[amxd55]]></dc:creator><pubDate>Thu, 15 Jul 2021 18:43:33 GMT</pubDate></item><item><title><![CDATA[Reply to Core Ink on Thu, 15 Jul 2021 06:34:31 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/amxd55" aria-label="Profile: amxd55">@<bdi>amxd55</bdi></a></p>
<p dir="auto">if you have a look at the sticker on the back of M5 CoreInk you'll see that <code>3.3 V</code> and <code>5 V OUT</code> are powered by USB or battery. I'd use a multimeter to measure between <code>5V OUT</code> and <code>GND</code>. It should read 5 V in both cases - USB or battery. If on battery the 5 V are not there then maybe the battery is flat?</p>
]]></description><link>https://community.m5stack.com/post/14408</link><guid isPermaLink="true">https://community.m5stack.com/post/14408</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 15 Jul 2021 06:34:31 GMT</pubDate></item></channel></rss>
