<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[UWB module not communicating through UART]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I purchased the UWB module (DW1000) and I currently have the device connected to a USB to UART bridge (CP2102). I cant seem to be able to send AT commands through the UART.<br />
I made sure device is communicating by disconnecting the device and connecting it back to the UART bride. I use putty (buad rate 115200 per documentation) and see that there is chatter. I have also tried to switch the RX and TX lines. I have also verified that my USB UART bride is outputting 5V.<br />
<img src="/assets/uploads/files/1626896643193-78065223-eb67-469c-ba47-a39a517fbfa3-image.png" alt="0_1626896641666_78065223-eb67-469c-ba47-a39a517fbfa3-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">The documentation says if you input the command "AT" it should return a message "OK", but I do not see that. If you have any advice on why this module is not working I would appreciate it!</p>
<p dir="auto"><a href="https://docs.m5stack.com/en/unit/uwb?id=description" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/en/unit/uwb?id=description</a></p>
]]></description><link>https://community.m5stack.com/topic/3469/uwb-module-not-communicating-through-uart</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 09:04:12 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3469.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 21 Jul 2021 19:52:16 GMT</pubDate><ttl>60</ttl></channel></rss>
