<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[My UnitV2 camera overheats within 5 minutes. Is that normal?]]></title><description><![CDATA[<p dir="auto">I just unboxed my V2 camera and let it do some object detection and it overheats within 5 minutes. I don't think there's a fan, but there should be a heat sink on it. Has anyone else had this problem?</p>
]]></description><link>https://community.m5stack.com/topic/3480/my-unitv2-camera-overheats-within-5-minutes-is-that-normal</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 01:05:58 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3480.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 24 Jul 2021 23:39:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to My UnitV2 camera overheats within 5 minutes. Is that normal? on Thu, 15 Dec 2022 03:29:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/viquaheeg520" aria-label="Profile: viquaheeg520">@<bdi>viquaheeg520</bdi></a> I have a number of cameras that have caught fire whilst operating on charge. The ESP32 has cracked and literally let the smoke out. Not sure if that is related but clearly I can't risk using the 30 or so units we bought.</p>
]]></description><link>https://community.m5stack.com/post/19562</link><guid isPermaLink="true">https://community.m5stack.com/post/19562</guid><dc:creator><![CDATA[iggym]]></dc:creator><pubDate>Thu, 15 Dec 2022 03:29:16 GMT</pubDate></item><item><title><![CDATA[Reply to My UnitV2 camera overheats within 5 minutes. Is that normal? on Sun, 26 Sep 2021 08:44:43 GMT]]></title><description><![CDATA[<p dir="auto">My new UnitV2 was overheating and shutting down as well during object detection. Running sudo cat /sys/devices/system/cpu/cpufreq/temp_out I could see the temperature consistently above 90 and and like you it only lasted for 5 mins before shutting down. I took the back off the unit and saw that the fan was oriented incorrectly - the fan output should point upwards so the air flows over the heatsink; mine was venting sideways! After re-orienting correctly the temperature stays around 70 degrees and no shutdowns :-). I hope this helps...</p>
]]></description><link>https://community.m5stack.com/post/14992</link><guid isPermaLink="true">https://community.m5stack.com/post/14992</guid><dc:creator><![CDATA[ViQuaheeg520]]></dc:creator><pubDate>Sun, 26 Sep 2021 08:44:43 GMT</pubDate></item></channel></rss>
