<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to power Core 2 from AC100v.]]></title><description><![CDATA[<p dir="auto">I measured the temperature and humidity, soil temperature and soil moisture using M5stack basic, sent it with sigfox, and could see it with ambient.<br />
Then I decided to do the same with M5stack core2.</p>
<p dir="auto">However, in the case of basic, it worked even if it was powered by the USB of the PC or from the AC adapter, but in core2 it works only by the USB power of the PC.</p>
<p dir="auto">Even if I supply power to core2 with an AC adapter, it does not start.</p>
<p dir="auto">I saw an article like this:<br />
When supplying power to core2 from AC100V,  press the power button, press and hold it, press it twice, or press the reset button. However, I tried everything but it didn't work.</p>
<p dir="auto">Does anyone know how to start up when using AC adapter power supply to core2?<br />
I would appreciate it if you could teach me.　Thank you.</p>
]]></description><link>https://community.m5stack.com/topic/3505/how-to-power-core-2-from-ac100v</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 02:47:36 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3505.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 08 Aug 2021 05:42:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to power Core 2 from AC100v. on Tue, 10 Aug 2021 05:40:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/takero" aria-label="Profile: takero">@<bdi>takero</bdi></a><br />
I write what happened after that.<br />
I bought a 2.5A AC adapter. I replaced it with a 1A adapter, but it didn't work.<br />
However, it works with power supplied from a PC.</p>
]]></description><link>https://community.m5stack.com/post/14609</link><guid isPermaLink="true">https://community.m5stack.com/post/14609</guid><dc:creator><![CDATA[takero]]></dc:creator><pubDate>Tue, 10 Aug 2021 05:40:31 GMT</pubDate></item><item><title><![CDATA[Reply to How to power Core 2 from AC100v. on Mon, 09 Aug 2021 10:33:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/microdynasty" aria-label="Profile: microdynasty">@<bdi>microdynasty</bdi></a><br />
Thank you for your answer.<br />
I saw the m5 spec says 5V @ 500mA. I used a 1A AC adapter.<br />
Does that mean it's small?</p>
]]></description><link>https://community.m5stack.com/post/14608</link><guid isPermaLink="true">https://community.m5stack.com/post/14608</guid><dc:creator><![CDATA[takero]]></dc:creator><pubDate>Mon, 09 Aug 2021 10:33:51 GMT</pubDate></item><item><title><![CDATA[Reply to How to power Core 2 from AC100v. on Sun, 08 Aug 2021 07:34:09 GMT]]></title><description><![CDATA[<p dir="auto">Well, I have perhaps 30 of the M5 units.  All of them power using the AC power USB adaptor.</p>
<p dir="auto">My advice is to be sure it has sufficient power (2.5A+)</p>
]]></description><link>https://community.m5stack.com/post/14595</link><guid isPermaLink="true">https://community.m5stack.com/post/14595</guid><dc:creator><![CDATA[microdynasty]]></dc:creator><pubDate>Sun, 08 Aug 2021 07:34:09 GMT</pubDate></item></channel></rss>
