<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Paper hangs when using Shutdown with something plugged on Ports]]></title><description><![CDATA[<p dir="auto">If I use the M5Paper alone, without any module plugged on Ports ABC, I am able to use the function Shutdown(time) and it works. However when some module is plugged in (for instance, the BPS sensor module) whenever i make a call to Shutdown(time) the system hangs. Is this an expected behavior?</p>
]]></description><link>https://community.m5stack.com/topic/3513/m5paper-hangs-when-using-shutdown-with-something-plugged-on-ports</link><generator>RSS for Node</generator><lastBuildDate>Tue, 05 May 2026 18:32:49 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3513.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 11 Aug 2021 08:58:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Paper hangs when using Shutdown with something plugged on Ports on Fri, 13 Aug 2021 04:38:27 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/inkto" aria-label="Profile: inkto">@<bdi>inkto</bdi></a></p>
<p dir="auto">just curious. How do you determine the system hangs? Care to share your program?</p>
]]></description><link>https://community.m5stack.com/post/14622</link><guid isPermaLink="true">https://community.m5stack.com/post/14622</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 13 Aug 2021 04:38:27 GMT</pubDate></item></channel></rss>
