<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[IR Sensor unit - Black socket for Core2. Can I plug it into the red Grove socket on my Core Grey?]]></title><description><![CDATA[<p dir="auto">Just like the title says!</p>
<p dir="auto">I've got a Core2 and the IR Sensor module. It's got a black connector for "Port B" on the Core2.</p>
<p dir="auto">The Core Grey doesn't have a Port B, but it does have a red Grove!<br />
Am I right in thinking the GND and +5 volts are the same pin positions on both?</p>
<p dir="auto">Does that mean I could potential change out the two data pins for Port B, to be those of the Grove port?</p>
<p dir="auto">I get that the Grove port and Port A and B have hardware support for some things like IC2, and erm... other control protocols. But for the IR Sensor, I believe I can use the pins in software, directly, just using "writeDigital" and "readDigital" ?</p>
<p dir="auto">Am I about to blow up my Core Grey!?</p>
]]></description><link>https://community.m5stack.com/topic/3521/ir-sensor-unit-black-socket-for-core2-can-i-plug-it-into-the-red-grove-socket-on-my-core-grey</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 08:46:29 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3521.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 15 Aug 2021 05:31:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to IR Sensor unit - Black socket for Core2. Can I plug it into the red Grove socket on my Core Grey? on Sun, 15 Aug 2021 15:15:39 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/sarahc" aria-label="Profile: SarahC">@<bdi>SarahC</bdi></a></p>
<p dir="auto">good to know. Thank you for sharing.</p>
]]></description><link>https://community.m5stack.com/post/14648</link><guid isPermaLink="true">https://community.m5stack.com/post/14648</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 15 Aug 2021 15:15:39 GMT</pubDate></item><item><title><![CDATA[Reply to IR Sensor unit - Black socket for Core2. Can I plug it into the red Grove socket on my Core Grey? on Sun, 15 Aug 2021 14:41:19 GMT]]></title><description><![CDATA[<p dir="auto">Thank you both!</p>
<p dir="auto">In the interests of experimentation... I just had to see what havoc using the Grove connector with the IR Unit would cause.</p>
<p dir="auto">I found that if I don't actively access the IC2 components, and just treat them as standard IO pins, they don't get in the way of any data I'm getting.</p>
<p dir="auto">I was able to demonstrate this really well with the IR Remote Control demo, using one Grove pin for the IR receiver, and turning the other Grove pin low to turn off the IR LED (which gets in the way of reception).</p>
<p dir="auto">I was able to scan 3 different remote controls, and also produce their raw flashes on the LCD as a diagram!</p>
<p dir="auto">For anyone that wants/needs to do this very un-recommended Grove useage:</p>
<pre><code>/*
   IRremoteESP8266: IRrecvDumpV3 - dump details of IR codes with IRrecv
   An IR detector/demodulator must be connected to the input kRecvPin.
   Copyright 2009 Ken Shirriff, http://arcfn.com
   Copyright 2017-2019 David Conran
   Example circuit diagram:
	https://github.com/crankyoldgit/IRremoteESP8266/wiki#ir-receiving
   Changes:
	 Version 1.2 October, 2020
	   - Enable easy setting of the decoding tolerance value.
	 Version 1.1 May, 2020
	   - Create DumpV3 from DumpV2
	   - Add OTA Base
	 Version 1.0 October, 2019
	   - Internationalisation (i18n) support.
	   - Stop displaying the legacy raw timing info.
	 Version 0.5 June, 2019
	   - Move A/C description to IRac.cpp.
	 Version 0.4 July, 2018
	   - Minor improvements and more A/C unit support.
	 Version 0.3 November, 2017
	   - Support for A/C decoding for some protocols.
	 Version 0.2 April, 2017
	   - Decode from a copy of the data so we can start capturing faster thus
		 reduce the likelihood of miscaptures.
   Based on Ken Shirriff's IrsendDemo Version 0.1 July, 2009,
// Allow over air update
// #define OTA_ENABLE true
//#include "BaseOTA.h"
#include &lt;M5Stack.h&gt;
//#include &lt;Arduino.h&gt;
#include &lt;assert.h&gt;
#include &lt;IRrecv.h&gt;
#include &lt;IRremoteESP8266.h&gt;
#include &lt;IRac.h&gt;
#include &lt;IRtext.h&gt;
#include &lt;IRutils.h&gt;
// M5Stack Core grey screen dimensions, and settings for the diagram display.
int dispWidth = 320;
int dispHeight = 240;
int stripNum = 0;
int stripsDownScreen = 6;
int stripHeight = dispHeight / stripsDownScreen;
// ==================== start of TUNEABLE PARAMETERS ====================
// An IR detector/demodulator is connected to GPIO pin 14
// e.g. D5 on a NodeMCU board.
// Note: GPIO 16 won't work on the ESP8266 as it does not have interrupts.
const uint16_t kRecvPin = 22; // Pin 22 on the M5Stack-Core-Grey.
// The Serial connection baud rate.
// i.e. Status message will be sent to the PC at this baud rate.
// Try to avoid slow speeds like 9600, as you will miss messages and
// cause other problems. 115200 (or faster) is recommended.
// NOTE: Make sure you set your Serial Monitor to the same speed.
const uint32_t kBaudRate = 115200;
// As this program is a special purpose capture/decoder, let us use a larger
// than normal buffer so we can handle Air Conditioner remote codes.
const uint16_t kCaptureBufferSize = 2048;
// kTimeout is the Nr. of milli-Seconds of no-more-data before we consider a
// message ended.
// This parameter is an interesting trade-off. The longer the timeout, the more
// complex a message it can capture. e.g. Some device protocols will send
// multiple message packets in quick succession, like Air Conditioner remotes.
// Air Coniditioner protocols often have a considerable gap (20-40+ms) between
// packets.
// The downside of a large timeout value is a lot of less complex protocols
// send multiple messages when the remote's button is held down. The gap between
// them is often also around 20+ms. This can result in the raw data be 2-3+
// times larger than needed as it has captured 2-3+ messages in a single
// capture. Setting a low timeout value can resolve this.
// So, choosing the best kTimeout value for your use particular case is
// quite nuanced. Good luck and happy hunting.
// NOTE: Don't exceed kMaxTimeoutMs. Typically 130ms.
#if DECODE_AC
// Some A/C units have gaps in their protocols of ~40ms. e.g. Kelvinator
// A value this large may swallow repeats of some protocols
const uint8_t kTimeout = 50; //50
#else   // DECODE_AC
// Suits most messages, while not swallowing many repeats.
const uint8_t kTimeout = 15; //15
#endif  // DECODE_AC
// Alternatives:
// const uint8_t kTimeout = 90;
// Suits messages with big gaps like XMP-1 &amp; some aircon units, but can
// accidentally swallow repeated messages in the rawData[] output.
// const uint8_t kTimeout = kMaxTimeoutMs;
// This will set it to our currently allowed maximum.
// Values this high are problematic because it is roughly the typical boundary
// where most messages repeat.
// e.g. It will stop decoding a message and start sending it to serial at
//      precisely the time when the next message is likely to be transmitted,
//      and may miss it.
// Set the smallest sized "UNKNOWN" message packets we actually care about.
// This value helps reduce the false-positive detection rate of IR background
// noise as real messages. The chances of background IR noise getting detected
// as a message increases with the length of the kTimeout value. (See above)
// The downside of setting this message too large is you can miss some valid
// short messages for protocols that this library doesn't yet decode.
// Set higher if you get lots of random short UNKNOWN messages when nothing
// should be sending a message.
// Set lower if you are sure your setup is working, but it doesn't see messages
// from your device. (e.g. Other IR remotes work.)
// NOTE: Set this value very high to effectively turn off UNKNOWN detection.
const uint16_t kMinUnknownSize = 12;
// How much percentage lee way do we give to incoming signals in order to match
// it?
// e.g. +/- 25% (default) to an expected value of 500 would mean matching a
//      value between 375 &amp; 625 inclusive.
// Note: Default is 25(%). Going to a value &gt;= 50(%) will cause some protocols
//       to no longer match correctly. In normal situations you probably do not
//       need to adjust this value. Typically that's when the library detects
//       your remote's message some of the time, but not all of the time.
const uint8_t kTolerancePercentage = kTolerance;  // kTolerance is normally 25%
// Legacy (No longer supported!)
// Change to `true` if you miss/need the old "Raw Timing[]" display.
#define LEGACY_TIMING_INFO false
// ==================== end of TUNEABLE PARAMETERS ====================
// Use turn on the save buffer feature for more complete capture coverage.
IRrecv irrecv(kRecvPin, kCaptureBufferSize, kTimeout, true);
decode_results results;  // Somewhere to store the results
// This section of code runs only once at start-up.
  // Setup the M5Core systems, and ready the screen.
  M5.begin();
  M5.Power.begin();
  M5.Lcd.fillScreen(WHITE);
  M5.Lcd.setTextColor(WHITE);
  M5.Lcd.setTextSize(1);
  M5.Lcd.setCursor(10, 10);
  // Turn off the IR LED - otherwise it makes noise for the receiver.
  pinMode(21, OUTPUT);
  digitalWrite(21, LOW);
  delay(100);
  //OTAwifi();  // start default wifi (previously saved on the ESP) for OTA
#if defined(ESP8266)
  Serial.begin(kBaudRate, SERIAL_8N1, SERIAL_TX_ONLY);
#else  // ESP8266
  Serial.begin(kBaudRate, SERIAL_8N1);
#endif  // ESP8266
  while (!Serial)  // Wait for the serial connection to be establised.
	delay(50);
  // Perform a low level sanity checks that the compiler performs bit field
  // packing as we expect and Endianness is as we expect.
  assert(irutils::lowLevelSanityCheck() == 0);
  Serial.printf("\n" D_STR_IRRECVDUMP_STARTUP "\n", kRecvPin);
  //OTAinit();  // setup OTA handlers and show IP
#if DECODE_HASH
  // Ignore messages with less than minimum on or off pulses.
  irrecv.setUnknownThreshold(kMinUnknownSize);
#endif  // DECODE_HASH
  irrecv.setTolerance(kTolerancePercentage);  // Override the default tolerance.
  irrecv.enableIRIn();  // Start the receiver
// The repeating section of the code
  // Check if the IR code has been received.
  if (irrecv.decode(&amp;results)) {
	// Display a crude timestamp.
	uint32_t now = millis();
	Serial.printf(D_STR_TIMESTAMP " : %06u.%03u\n", now / 1000, now % 1000);
	// Check if we got an IR message that was to big for our capture buffer.
	if (results.overflow)
	  Serial.printf(D_WARN_BUFFERFULL "\n", kCaptureBufferSize);
	// Display the library version the message was captured with.
	Serial.println(D_STR_LIBRARY "   : v" _IRREMOTEESP8266_VERSION_ "\n");
	// Display the tolerance percentage if it has been change from the default.
	if (kTolerancePercentage != kTolerance)
	  Serial.printf(D_STR_TOLERANCE " : %d%%\n", kTolerancePercentage);
	// Display the basic output of what we found.
	Serial.print(resultToHumanReadableBasic(&amp;results));
	// Display any extra A/C info if we have it.
	String description = IRAcUtils::resultAcToString(&amp;results);
	if (description.length()) Serial.println(D_STR_MESGDESC ": " + description);
	yield();  // Feed the WDT as the text output can take a while to print.
#if LEGACY_TIMING_INFO
	// Output legacy RAW timing info of the result.
	Serial.println(resultToTimingInfo(&amp;results));
	yield();  // Feed the WDT (again)
#endif  // LEGACY_TIMING_INFO
	// Output the results as source code
	Serial.println(resultToSourceCode(&amp;results));
	// Draw the next strip containing the signal. Scale to fit the screen, and the length of the signal.
	double timingTotal = 0;
	int arrayLength = getCorrectedRawLength(&amp;results);
	uint16_t *timings = resultToRawArray(&amp;results);
	for (int i = 0; i &lt; arrayLength; i++) {
	  timingTotal += timings[i];
	int y = stripNum * stripHeight;
	int currentTotal = 0;
	double scaler = (double)dispWidth / (double)timingTotal;
	uint16_t col = 1;
	for (uint16_t i = 0; i &lt; arrayLength - 1; i++) {
	  double timeWidth = ((double)timings[i] * scaler);
	  double timeX = (currentTotal * scaler);
	  currentTotal += timings[i];
	  M5.Lcd.fillRect((int)timeX, (int)y, (int)timeWidth, stripHeight - 2, col ? BLACK : WHITE);
	  col = 1 - col;
	if (++stripNum == stripsDownScreen) stripNum = 0;
	Serial.println();    // Blank line between entries
]]></description><link>https://community.m5stack.com/post/14646</link><guid isPermaLink="true">https://community.m5stack.com/post/14646</guid><dc:creator><![CDATA[SarahC]]></dc:creator><pubDate>Sun, 15 Aug 2021 14:41:19 GMT</pubDate></item><item><title><![CDATA[Reply to IR Sensor unit - Black socket for Core2. Can I plug it into the red Grove socket on my Core Grey? on Sun, 15 Aug 2021 11:16:53 GMT]]></title><description><![CDATA[<p dir="auto">yes, just remember to set port A in the drop down box that appears below the icon in uiflow</p>
]]></description><link>https://community.m5stack.com/post/14645</link><guid isPermaLink="true">https://community.m5stack.com/post/14645</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 15 Aug 2021 11:16:53 GMT</pubDate></item><item><title><![CDATA[Reply to IR Sensor unit - Black socket for Core2. Can I plug it into the red Grove socket on my Core Grey? on Sun, 15 Aug 2021 09:03:23 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/sarahc" aria-label="Profile: SarahC">@<bdi>SarahC</bdi></a></p>
<p dir="auto">M5Stack Gray shares the same two GPIOs between port A and the internal I2C ICs (e.g. IIP5306, MPU6886 and BMM150). So yes, in theory you could repurpose those two GPIOs for something else than I2C, but most likely it won't work as it conflicts with the internal I2C ICs.</p>
<p dir="auto">M5Core2 on the other hand uses two pairs of GPIOs, one pair for internal and one pair for external I2C, so changing the functionality of the external I2C GPIOs (aka port A) is possible.</p>
]]></description><link>https://community.m5stack.com/post/14642</link><guid isPermaLink="true">https://community.m5stack.com/post/14642</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 15 Aug 2021 09:03:23 GMT</pubDate></item></channel></rss>
