<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Change I2C address of joystick module]]></title><description><![CDATA[<p dir="auto">hi,<br />
does anyone know if it is possible to change the i2c address of a joystick module? I would like to use two joysticks on the port A.<br />
I am very geartful for any hint..<br />
thanks and regards<br />
tom</p>
]]></description><link>https://community.m5stack.com/topic/3547/change-i2c-address-of-joystick-module</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 14:20:32 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3547.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 27 Aug 2021 08:54:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Change I2C address of joystick module on Tue, 31 Aug 2021 05:09:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> they are, its just that it takes a bit of comparison work to spot them.<br />
they appear as R17, R18 and R19.</p>
]]></description><link>https://community.m5stack.com/post/14769</link><guid isPermaLink="true">https://community.m5stack.com/post/14769</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 31 Aug 2021 05:09:58 GMT</pubDate></item><item><title><![CDATA[Reply to Change I2C address of joystick module on Mon, 30 Aug 2021 22:36:06 GMT]]></title><description><![CDATA[<p dir="auto">Hello guys</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> : that is interesting - thanks for sharing.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tttttttom" aria-label="Profile: tttttttom">@<bdi>tttttttom</bdi></a> : sorry for misleading you.</p>
<p dir="auto">Also interestingly these address pins are not mentioned in the <a href="https://docs.m5stack.com/en/unit/joystick?id=schematic" target="_blank" rel="noopener noreferrer nofollow ugc">schematic</a>.</p>
]]></description><link>https://community.m5stack.com/post/14767</link><guid isPermaLink="true">https://community.m5stack.com/post/14767</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Mon, 30 Aug 2021 22:36:06 GMT</pubDate></item><item><title><![CDATA[Reply to Change I2C address of joystick module on Mon, 30 Aug 2021 14:30:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> is correct here that the PaHub is what needed however,<br />
There is a header inside that if you solder the pins, the address will change.<img src="/assets/uploads/files/1630333828048-address-resized.png" alt="0_1630333824840_address.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/14762</link><guid isPermaLink="true">https://community.m5stack.com/post/14762</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 30 Aug 2021 14:30:31 GMT</pubDate></item><item><title><![CDATA[Reply to Change I2C address of joystick module on Mon, 30 Aug 2021 07:06:39 GMT]]></title><description><![CDATA[<p dir="auto">Hello Felix,<br />
thank you for sharing your knowledge. And yes, my question concerns the joystick UNIT. And yes, I would like to change the i2c address inside the MEGA328P. But the unit you are mentioning is also fine. I will check that ...<br />
Regards<br />
Tom</p>
]]></description><link>https://community.m5stack.com/post/14761</link><guid isPermaLink="true">https://community.m5stack.com/post/14761</guid><dc:creator><![CDATA[tttttttom]]></dc:creator><pubDate>Mon, 30 Aug 2021 07:06:39 GMT</pubDate></item><item><title><![CDATA[Reply to Change I2C address of joystick module on Sat, 28 Aug 2021 09:48:04 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/tttttttom" aria-label="Profile: tttttttom">@<bdi>tttttttom</bdi></a></p>
<p dir="auto">if I am not mistaken there is no joystick module - did you mean the joystick unit?</p>
<p dir="auto">The <a href="https://shop.m5stack.com/products/joystick-unit" target="_blank" rel="noopener noreferrer nofollow ugc">joystick unit</a> uses an MEGA328P processor inside which most likely has the I2C address programmed in it and I cannot find the source of the firmware running inside the MEGA328. Given that I would say you cannot change the I2C address.</p>
<p dir="auto">Your best bet would be a <a href="https://shop.m5stack.com/products/pahub-unit" target="_blank" rel="noopener noreferrer nofollow ugc">PaHub unit</a> which has been developed exactly to solve that use case.</p>
]]></description><link>https://community.m5stack.com/post/14748</link><guid isPermaLink="true">https://community.m5stack.com/post/14748</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sat, 28 Aug 2021 09:48:04 GMT</pubDate></item></channel></rss>
