<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Core2 keeps rebooting with PoE base]]></title><description><![CDATA[<p dir="auto">I am trying to get Core2 working with PoE base, but when powered from PoE it doesn’t start. Core keeps power cycling on PoE, but works just fine with external power.<br />
Tried with 2 different cores and 2 different bases.<br />
Also tried with different PoE switches/cables.</p>
<p dir="auto">Original core works fine in the same setup.<br />
When powering from USB-C Ethernet from PoE base works fine.</p>
<p dir="auto">What could be the reason why it doesn’t work?</p>
]]></description><link>https://community.m5stack.com/topic/3551/core2-keeps-rebooting-with-poe-base</link><generator>RSS for Node</generator><lastBuildDate>Tue, 05 May 2026 01:44:50 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3551.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 30 Aug 2021 16:05:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Core2 keeps rebooting with PoE base on Tue, 31 Aug 2021 08:28:18 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/e-d" aria-label="Profile: e-d">@<bdi>e-d</bdi></a></p>
<p dir="auto">I don't think this particular parameter has been documented (yet) for the LAN PoE module. It has for some of the newer COMX modules which also can be powered externally.</p>
<p dir="auto">Another reason, I guess, is, that with M5Stack devices (Fire, Gray, Base) there is no need to switch between output and input as they use a different electrical circuit than M5Core2, which allows the power pin to be both (input and output) at the same time.</p>
<p dir="auto">As for learning about these parameters - sometimes looking at the Arduino libraries and / or schematic helps figuring out how things are meant to work.</p>
]]></description><link>https://community.m5stack.com/post/14772</link><guid isPermaLink="true">https://community.m5stack.com/post/14772</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Tue, 31 Aug 2021 08:28:18 GMT</pubDate></item><item><title><![CDATA[Reply to Core2 keeps rebooting with PoE base on Tue, 31 Aug 2021 05:26:24 GMT]]></title><description><![CDATA[<p dir="auto">Hello Felix,</p>
<p dir="auto">Thank you, I will try this! Is this documented somewhere? Just curious how to learn about these parameters and what are the other parameters.</p>
]]></description><link>https://community.m5stack.com/post/14770</link><guid isPermaLink="true">https://community.m5stack.com/post/14770</guid><dc:creator><![CDATA[e-d]]></dc:creator><pubDate>Tue, 31 Aug 2021 05:26:24 GMT</pubDate></item><item><title><![CDATA[Reply to Core2 keeps rebooting with PoE base on Mon, 30 Aug 2021 22:30:34 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/e-d" aria-label="Profile: e-d">@<bdi>e-d</bdi></a></p>
<p dir="auto">have you tried to change the fifth (last) parameter of <code>M5.begin()</code> to <code>kMBusModeInput</code>?</p>
<p dir="auto">Explanation: M5Core2 starts to boot up from external power (e.g. from PoE), but when <code>M5.begin()</code> is executed (which uses <code>kMBusModeOutput</code> by default) that changes the power source to either battery or USB (which are not present) and thus M5Core2 reboots and so on.</p>
]]></description><link>https://community.m5stack.com/post/14766</link><guid isPermaLink="true">https://community.m5stack.com/post/14766</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Mon, 30 Aug 2021 22:30:34 GMT</pubDate></item></channel></rss>
