<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[AtomDTU NB-IoT not detecting SIM card]]></title><description><![CDATA[<p dir="auto">Hi, I have tried two different ATOMDTU/NB-IoT modules and two different Sim cards but AT commands show Sim not detected. Any advice?<br />
see details from AT test:</p>
<p dir="auto">ati<br />
SIM7020G R1910<br />
OK</p>
<p dir="auto">at+gmm<br />
SIM7020G<br />
OK</p>
<p dir="auto">at+gmr<br />
1910B03SIM7020G<br />
OK</p>
<p dir="auto">at+gsn<br />
86151xxxxxxxxxx<br />
OK</p>
<p dir="auto">at+cgsn<br />
86151xxxxxxxxx<br />
OK</p>
<p dir="auto">at+cpin?<br />
+CME ERROR: SIM not inserted</p>
<p dir="auto">See does not detect sim card</p>
<p dir="auto">also LED status is:<br />
red=on<br />
blue= quick flash once per second</p>
<p dir="auto">Thanks</p>
]]></description><link>https://community.m5stack.com/topic/3552/atomdtu-nb-iot-not-detecting-sim-card</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 14:08:49 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3552.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 31 Aug 2021 02:48:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to AtomDTU NB-IoT not detecting SIM card on Mon, 11 Oct 2021 20:35:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> Thank you Felix!</p>
]]></description><link>https://community.m5stack.com/post/15101</link><guid isPermaLink="true">https://community.m5stack.com/post/15101</guid><dc:creator><![CDATA[MTal]]></dc:creator><pubDate>Mon, 11 Oct 2021 20:35:17 GMT</pubDate></item><item><title><![CDATA[Reply to AtomDTU NB-IoT not detecting SIM card on Sun, 10 Oct 2021 11:15:48 GMT]]></title><description><![CDATA[<p dir="auto">Hi guys</p>
<p dir="auto">to set the APN you could try to add an <code>Execute code</code> block with the following content:</p>
<pre><code>dtu_nb.send_at_cmd("AT+CGDCONT=1,\"IP\",\"your_apn_here\"")
<p dir="auto">Please note the string quoting <code>\"</code> and replace <code>your_apn_here</code> with the one you intend to use.</p>
]]></description><link>https://community.m5stack.com/post/15088</link><guid isPermaLink="true">https://community.m5stack.com/post/15088</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 10 Oct 2021 11:15:48 GMT</pubDate></item><item><title><![CDATA[Reply to AtomDTU NB-IoT not detecting SIM card on Thu, 07 Oct 2021 10:50:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gmang" aria-label="Profile: gmang">@<bdi>gmang</bdi></a> same here, I also need to change the APN from UIFLOW, did you already solved it?</p>
]]></description><link>https://community.m5stack.com/post/15073</link><guid isPermaLink="true">https://community.m5stack.com/post/15073</guid><dc:creator><![CDATA[MTal]]></dc:creator><pubDate>Thu, 07 Oct 2021 10:50:06 GMT</pubDate></item><item><title><![CDATA[Reply to AtomDTU NB-IoT not detecting SIM card on Tue, 31 Aug 2021 16:10:18 GMT]]></title><description><![CDATA[<p dir="auto">I also noted there is no way to set the APN details using UIFlow.<br />
I see that using M5Burner one can set the apn using the configuration button on Core, but not on UIFlow_Lite.<br />
Any advice to add APN setup and still use UIFlow</p>
]]></description><link>https://community.m5stack.com/post/14779</link><guid isPermaLink="true">https://community.m5stack.com/post/14779</guid><dc:creator><![CDATA[gmang]]></dc:creator><pubDate>Tue, 31 Aug 2021 16:10:18 GMT</pubDate></item><item><title><![CDATA[Reply to AtomDTU NB-IoT not detecting SIM card on Tue, 31 Aug 2021 16:06:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a><br />
RESOLVED: I had the sim card backwards. even though there is a big picture of how to insert it, i still inserted it cut-side first out of habit.<br />
Thanks for pointing it out.</p>
]]></description><link>https://community.m5stack.com/post/14778</link><guid isPermaLink="true">https://community.m5stack.com/post/14778</guid><dc:creator><![CDATA[gmang]]></dc:creator><pubDate>Tue, 31 Aug 2021 16:06:28 GMT</pubDate></item><item><title><![CDATA[Reply to AtomDTU NB-IoT not detecting SIM card on Tue, 31 Aug 2021 07:09:47 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/gmang" aria-label="Profile: gmang">@<bdi>gmang</bdi></a></p>
<p dir="auto">have you inserted the SIM card in the correct orientation? According to the <a href="https://shop.m5stack.com/collections/m5stack-new-arrival/products/atom-dtu-nb-iot-kit-global-version-sim7020g" target="_blank" rel="noopener noreferrer nofollow ugc">second picture here</a> the orientation seems to be up side down and the cut edge towards the outside (which for me was a bit counter intuitive.)</p>
]]></description><link>https://community.m5stack.com/post/14771</link><guid isPermaLink="true">https://community.m5stack.com/post/14771</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Tue, 31 Aug 2021 07:09:47 GMT</pubDate></item></channel></rss>
