<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Stamp-Pico Arduino lib?]]></title><description><![CDATA[<p dir="auto"><a href="https://docs.m5stack.com/en/arduino/arduino_development" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/en/arduino/arduino_development</a> mentions the new stamp-pico, but falls short of mentioning what library/header one uses in an Arduino Stamp sketch for it.<br />
Would it use M5Atom.h?<br />
Thanks!</p>
]]></description><link>https://community.m5stack.com/topic/3575/stamp-pico-arduino-lib</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 19:12:17 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3575.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 10 Sep 2021 22:26:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Stamp-Pico Arduino lib? on Sat, 18 Sep 2021 22:14:17 GMT]]></title><description><![CDATA[<p dir="auto">Felix; thanks for the tip in the Grove pinout; exactly where I was stuck after experimenting.</p>
]]></description><link>https://community.m5stack.com/post/14899</link><guid isPermaLink="true">https://community.m5stack.com/post/14899</guid><dc:creator><![CDATA[vkichline]]></dc:creator><pubDate>Sat, 18 Sep 2021 22:14:17 GMT</pubDate></item><item><title><![CDATA[Reply to Stamp-Pico Arduino lib? on Sun, 12 Sep 2021 07:55:34 GMT]]></title><description><![CDATA[<p dir="auto">The M5Stamp uses an ESP32 PICO D4 and so any library that supports the Pico D4 is usable.<br />
You just need to make sure to define the pins correctly in your code.<br />
StickC and Atom are both Pico D4 and should be ok but will have different pins defined.</p>
]]></description><link>https://community.m5stack.com/post/14863</link><guid isPermaLink="true">https://community.m5stack.com/post/14863</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 12 Sep 2021 07:55:34 GMT</pubDate></item><item><title><![CDATA[Reply to Stamp-Pico Arduino lib? on Fri, 10 Sep 2021 23:00:34 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/vkichline" aria-label="Profile: vkichline">@<bdi>vkichline</bdi></a></p>
<p dir="auto">interesting question. Looking at the schematics of M5Atom and M5Stamp it looks like they are mostly the same.<br />
Same:</p>
<li>ESP32 PICO</li>
<li>RGB LED - GPIO27</li>
<li>Button - GPIO39</li>
<p dir="auto">Different:</p>
<li>Groove - GPIO32/26 (M5Atom) vs. GPIO33/32 (M5Stamp)</li>
<p dir="auto">So, yes, I'd say using the M5Atom Arduino library should get you started.</p>
]]></description><link>https://community.m5stack.com/post/14858</link><guid isPermaLink="true">https://community.m5stack.com/post/14858</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 10 Sep 2021 23:00:34 GMT</pubDate></item></channel></rss>
