<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[COM.X 915 Doesn&#x27;t respond]]></title><description><![CDATA[<p dir="auto">I just got my COM.X modules in the mail. I was looking forward to playing around with these and maybe creating a point to point network of sorts. Just to play with, maybe transmit weather data. I don't seem to get any response with the module though. I was following the <a href="https://www.hackster.io/sodoku/m5stack-com-lorawan-using-uiflow-fdcd7f" target="_blank" rel="noopener noreferrer nofollow ugc">M5Stack Tutorial</a> with the Grey Core. I have everything as shown in the picture in the tutorial as far as RX/TX pins. I get no response at all in the M5 Burner, but if I open the serial monitor in the Arduino IDE, I get the following ERROR. Any ideas where to start? Do I need to register this with the TTN  or set the frequency or something? Also, I can't help but think the pins on the module are slightly too short and may not be getting a good connection.</p>
<p dir="auto">AT+LORAWAN=?</p>
<p dir="auto">+CME ERROR:1</p>
<p dir="auto">ASR6501:~#</p>
]]></description><link>https://community.m5stack.com/topic/3576/com-x-915-doesn-t-respond</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 10:02:33 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3576.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 11 Sep 2021 12:06:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to COM.X 915 Doesn&#x27;t respond on Sun, 12 Sep 2021 19:37:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> said in <a href="/post/14865">COM.X 915 Doesn't respond</a>:</p>
<p dir="auto">AT+LORAWAN=?<br />
Thank you for the help. That was all it was. I fired it back up again and issues commands from the correct command set and it seems to be working. Now to try it out more.</p>
<p dir="auto">Thank you!<br />
Kelly</p>
]]></description><link>https://community.m5stack.com/post/14868</link><guid isPermaLink="true">https://community.m5stack.com/post/14868</guid><dc:creator><![CDATA[ksprayberry]]></dc:creator><pubDate>Sun, 12 Sep 2021 19:37:23 GMT</pubDate></item><item><title><![CDATA[Reply to COM.X 915 Doesn&#x27;t respond on Sun, 12 Sep 2021 10:15:30 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/ksprayberry" aria-label="Profile: ksprayberry">@<bdi>ksprayberry</bdi></a></p>
<p dir="auto">the first thing you'll need to know is that the tutorial is using the <strong>868 MHz</strong> LoRa module whereas you are using the <strong>915 MHz</strong> LoRa Module. Unfortunately they don't use the same AT command set, so you'll need to adapt the tutorial for your module.</p>
<p dir="auto">For instance the 915 MHz module doesn't seem to have the <code>AT+LORAWAN=?</code> command and that is the reason you'll get the error.</p>
<p dir="auto">Please check out the related links section <a href="https://docs.m5stack.com/en/module/comx_lorawan915" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
<p dir="auto">BTW: the fact that you are seeing an error for the AT command given tells you that the RX/TX pins are correct.</p>
<p dir="auto">BTW: the <code>ASR6501:~#</code> line simply means, the modem went back to sleep.</p>
]]></description><link>https://community.m5stack.com/post/14865</link><guid isPermaLink="true">https://community.m5stack.com/post/14865</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 12 Sep 2021 10:15:30 GMT</pubDate></item></channel></rss>
