<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Problem when stacking, plug too loose]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I have a M5Stack FIRE and I want to stack a GPS module and the COM.LoRaWAN module.<br />
The GPS module holds great and other modules that are plugged in also hold well. The COM.LoRaWAN module also holds well when I plug it onto the GPS module, but I can't plug anything onto the COM.LoRaWAN module because it won't hold because the connector is not deep enough.<br />
Is this a known bug?<br />
What can be done to fix the problem?</p>
<p dir="auto">Regards,<br />
Oliver</p>
]]></description><link>https://community.m5stack.com/topic/3577/problem-when-stacking-plug-too-loose</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 03:51:01 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3577.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 12 Sep 2021 06:35:22 GMT</pubDate><ttl>60</ttl></channel></rss>
