<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Quest about WIFI connection]]></title><description><![CDATA[<p dir="auto">Is the M5Stack WIFI scan area larger than smartphone? When my smartphone cannot scan my wifi, M5stack still print that it can scan and connect to the wifi.</p>
]]></description><link>https://community.m5stack.com/topic/359/quest-about-wifi-connection</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 04:56:59 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/359.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 11 Oct 2018 04:42:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Quest about WIFI connection on Fri, 12 Oct 2018 01:57:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rop" aria-label="Profile: rop">@<bdi>rop</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a></p>
<p dir="auto">I have no idea. So i just force disconnect if the RSSI of the WiFi is too low.</p>
]]></description><link>https://community.m5stack.com/post/1710</link><guid isPermaLink="true">https://community.m5stack.com/post/1710</guid><dc:creator><![CDATA[ken57093]]></dc:creator><pubDate>Fri, 12 Oct 2018 01:57:28 GMT</pubDate></item><item><title><![CDATA[Reply to Quest about WIFI connection on Thu, 11 Oct 2018 16:22:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ken57093" aria-label="Profile: ken57093">@<bdi>ken57093</bdi></a> 在 <a href="/post/1698">Quest about WIFI connection</a> 中说：</p>
<p dir="auto">technically they should have the same range however metal in the case and crappy antenna design on the phone can cause issues.<br />
Also the phones software may decide not to work.<br />
If a phone is not switched off (fully off not standby or sleep) data stored in memory will cause the phone not to detect properly.<br />
I have seen this with samsung, sony and apple phone, and also with both linux, windows and OSX based computers!<br />
Best tip I can find is to delete all stored connections to wifi networks, switch off wifi, Do a full powerdown of pc/phone. wait 5 mins, then reboot device.</p>
]]></description><link>https://community.m5stack.com/post/1706</link><guid isPermaLink="true">https://community.m5stack.com/post/1706</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 11 Oct 2018 16:22:01 GMT</pubDate></item><item><title><![CDATA[Reply to Quest about WIFI connection on Thu, 11 Oct 2018 14:34:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ken57093" aria-label="Profile: ken57093">@<bdi>ken57093</bdi></a> Uhhh, I dunno. Try?</p>
<p dir="auto">(If you use M5ez, you can see if it's still connected, and it will auto-connect when it sees a know access point, so that's easy to test with...)</p>
]]></description><link>https://community.m5stack.com/post/1705</link><guid isPermaLink="true">https://community.m5stack.com/post/1705</guid><dc:creator><![CDATA[Rop]]></dc:creator><pubDate>Thu, 11 Oct 2018 14:34:17 GMT</pubDate></item><item><title><![CDATA[Reply to Quest about WIFI connection on Thu, 11 Oct 2018 08:49:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rop" aria-label="Profile: rop">@<bdi>rop</bdi></a></p>
<p dir="auto">Thank you.</p>
<p dir="auto">I also want to ask that will it auto disconnect from the wifi when it is no internet access? Or I have to use WiFi.disconnect() to force it disconnect? when i walk too far from the router, it still connect to the wifi but cannot connect to internet</p>
]]></description><link>https://community.m5stack.com/post/1701</link><guid isPermaLink="true">https://community.m5stack.com/post/1701</guid><dc:creator><![CDATA[ken57093]]></dc:creator><pubDate>Thu, 11 Oct 2018 08:49:06 GMT</pubDate></item><item><title><![CDATA[Reply to Quest about WIFI connection on Thu, 11 Oct 2018 06:42:05 GMT]]></title><description><![CDATA[<p dir="auto">Depends on the smartphone...</p>
<p dir="auto">I've also noticed it's not bad at all for a device whose makers could spend only a fraction of the development budget of the Apples and Samsungs of the world. But then smartphones have way, way more throughput than an ESP32.</p>
]]></description><link>https://community.m5stack.com/post/1699</link><guid isPermaLink="true">https://community.m5stack.com/post/1699</guid><dc:creator><![CDATA[Rop]]></dc:creator><pubDate>Thu, 11 Oct 2018 06:42:05 GMT</pubDate></item></channel></rss>
