<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Hello may i know how to resolve this error]]></title><description><![CDATA[<p dir="auto">Arduino: 1.8.16 (Mac OS X), Board: "ESP32 Pico Kit, Default, 921600, None"</p>
<p dir="auto">Sketch uses 273310 bytes (20%) of program storage space. Maximum is 1310720 bytes.<br />
Global variables use 15384 bytes (4%) of dynamic memory, leaving 312296 bytes for local variables. Maximum is 327680 bytes.<br />
<a href="http://esptool.py" target="_blank" rel="noopener noreferrer nofollow ugc">esptool.py</a> v3.0-dev<br />
Serial port /dev/cu.usbserial-2552473181<br />
Connecting.....<br />
Chip is ESP32-PICO-D4 (revision 1)<br />
Features: WiFi, BT, Dual Core, 240MHz, Embedded Flash, VRef calibration in efuse, Coding Scheme None<br />
Crystal is 40MHz<br />
MAC: 94:b9:7e:ad:24:10<br />
Uploading stub...<br />
Running stub...<br />
Stub running...<br />
Changing baud rate to 921600<br />
Changed.<br />
Configuring flash size...</p>
<p dir="auto">A fatal error occurred: Timed out waiting for packet header<br />
A fatal error occurred: Timed out waiting for packet header</p>
<p dir="auto">This report would have more information with<br />
"Show verbose output during compilation"<br />
option enabled in File -&gt; Preferences.</p>
]]></description><link>https://community.m5stack.com/topic/3596/hello-may-i-know-how-to-resolve-this-error</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 00:05:23 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3596.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 24 Sep 2021 04:41:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Hello may i know how to resolve this error on Sun, 26 Sep 2021 02:14:39 GMT]]></title><description><![CDATA[<p dir="auto">try to use 115200 baud rate?</p>
]]></description><link>https://community.m5stack.com/post/14984</link><guid isPermaLink="true">https://community.m5stack.com/post/14984</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Sun, 26 Sep 2021 02:14:39 GMT</pubDate></item><item><title><![CDATA[Reply to Hello may i know how to resolve this error on Fri, 24 Sep 2021 17:53:27 GMT]]></title><description><![CDATA[<p dir="auto">cu.usbserial is not the correct device. have you installed the cp2102 vcp driver?</p>
]]></description><link>https://community.m5stack.com/post/14966</link><guid isPermaLink="true">https://community.m5stack.com/post/14966</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 24 Sep 2021 17:53:27 GMT</pubDate></item></channel></rss>
