<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[UIFlow 1.8.5]]></title><description><![CDATA[<h3>v1.8.5</h3>
<h4>new features</h4>
<li>ZH-CN:
<li>UNIT MQTT支持</li>
<li>UNIT RTC支持</li>
<li>ADD EzData功能</li>
</li>
<li>EN:
<li>Add UNIT MQTT support</li>
<li>Add UNIT RTC support</li>
<li>ADD EzData support</li>
</li>
]]></description><link>https://community.m5stack.com/topic/3607/uiflow-1-8-5</link><generator>RSS for Node</generator><lastBuildDate>Fri, 01 May 2026 07:13:36 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3607.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 30 Sep 2021 11:19:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to UIFlow 1.8.5 on Fri, 05 Nov 2021 09:30:09 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a></p>
<p dir="auto">it looks like there might be an issue with the Vibration Motor Unit which only runs very slowly or not at all when using the dedicated blocks. However when using the analog output directly it works. The difference is with the dedicated block the GPIO output doesn't go higher than 0.5 V whereas with the analog block it goes up to 3.3 V as expected.</p>
<p dir="auto">Note: I personally do not have a Vibration Motor Unit - my conclusion is solely based on looking at the schematic and measuring the GPIO output of my M5StickC Plus using either of the aforementioned blocks.</p>
<p dir="auto">However user <a class="plugin-mentions-user plugin-mentions-a" href="/user/dailletaille" aria-label="Profile: dailletaille">@<bdi>dailletaille</bdi></a> verified it to work with the analog block, so please also see this topic <a href="https://community.m5stack.com/topic/3692/vibrator-motor-unit-not-working-correctly">here</a>.</p>
]]></description><link>https://community.m5stack.com/post/15367</link><guid isPermaLink="true">https://community.m5stack.com/post/15367</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 05 Nov 2021 09:30:09 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.8.5 on Tue, 19 Oct 2021 17:11:57 GMT]]></title><description><![CDATA[<p dir="auto">Firmware is in M5Burner, UIFlow online is already updated.</p>
]]></description><link>https://community.m5stack.com/post/15169</link><guid isPermaLink="true">https://community.m5stack.com/post/15169</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 19 Oct 2021 17:11:57 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.8.5 on Mon, 18 Oct 2021 08:26:17 GMT]]></title><description><![CDATA[<p dir="auto">Hello</p>
<p dir="auto">Where can I download. Version 1.8.5 of UI flow.</p>
<p dir="auto">Ken</p>
]]></description><link>https://community.m5stack.com/post/15153</link><guid isPermaLink="true">https://community.m5stack.com/post/15153</guid><dc:creator><![CDATA[Flow]]></dc:creator><pubDate>Mon, 18 Oct 2021 08:26:17 GMT</pubDate></item></channel></rss>
