<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Typ B (black connection) Units,not working with core2]]></title><description><![CDATA[<p dir="auto">Please advise me on this.<br />
I have a core2 which I use with the UI flow<br />
All my type  A (red) units (heart, env, air quality), are fine<br />
The port B type (black) units (rf, buttons, rgb, ir)connect, but are not read.<br />
What are my options?<br />
Thanks</p>
]]></description><link>https://community.m5stack.com/topic/3614/typ-b-black-connection-units-not-working-with-core2</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 08:45:20 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3614.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 02 Oct 2021 07:43:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Typ B (black connection) Units,not working with core2 on Sat, 02 Oct 2021 07:49:33 GMT]]></title><description><![CDATA[<p dir="auto">Port A units are digital/i2c and so will work as you have noticed.<br />
PortB units are analogue devices.<br />
You can try a PortBHub which will convert analogue to digital or you can try the GoPlus2 module which has analogue pins.<br />
Alternatively, on the base plate of the Core2 remove the expansion module and you will have access to the MBus connectors with analogue pins.</p>
]]></description><link>https://community.m5stack.com/post/15037</link><guid isPermaLink="true">https://community.m5stack.com/post/15037</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 02 Oct 2021 07:49:33 GMT</pubDate></item></channel></rss>
