<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Core and Core2 compatibility]]></title><description><![CDATA[<p dir="auto">I want to learn more about the M5 Stack Core 2, but I have hit a dead end.</p>
<p dir="auto">I am keen to load the Blockly version of the Weather Station (Lesson 7 on Youtube). No luck.</p>
<p dir="auto">Is the Core 2 compatible with Core based software? I have loaded the code as shown but I have just a white screen - nothing more, so I suspect this particular example is not compatible???</p>
<p dir="auto">The other confusing part is I have seen versions of UI Flow that offer a range of examples accessed via the top icon row (right hand side) including the Weather Station example that I am interested in. I cant always see this.  I am currently using 1.7.1. The version shown on the M5 is Core2 1.8.5, which is also confusing.</p>
<p dir="auto">Any help getting me out this problem would be appreciated.</p>
<p dir="auto">Ken</p>
]]></description><link>https://community.m5stack.com/topic/3625/core-and-core2-compatibility</link><generator>RSS for Node</generator><lastBuildDate>Sat, 02 May 2026 01:41:19 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3625.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 08 Oct 2021 06:10:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Core and Core2 compatibility on Fri, 08 Oct 2021 15:40:55 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/flow" aria-label="Profile: Flow">@<bdi>Flow</bdi></a></p>
<p dir="auto">if in the online version (1.8.5) of UIFlow I select M5Core2 then under Demo (button top right) I only see the drawing board app, however when I select M5Stack (Base) I see multiple example apps under Demo, including the Weather Station.</p>
<p dir="auto">In other words, the examples build for M5Stack are in general not compatible with M5Core2 and vice versa.</p>
<p dir="auto">I guess your options are to either take the M5Stack examples and try to adapt / rebuild them to M5Core2 or get an M5Stack.</p>
]]></description><link>https://community.m5stack.com/post/15077</link><guid isPermaLink="true">https://community.m5stack.com/post/15077</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 08 Oct 2021 15:40:55 GMT</pubDate></item></channel></rss>
