<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Bootloop]]></title><description><![CDATA[<p dir="auto">Did anybody seen similar?<br />
I have no idea how to repair.<br />
<img src="/assets/uploads/files/1634106872297-bug.jpg" alt="0_1634106878005_bug.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/topic/3638/bootloop</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 11:31:48 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3638.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 13 Oct 2021 06:35:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Bootloop on Thu, 21 Oct 2021 17:13:17 GMT]]></title><description><![CDATA[<p dir="auto">Right, OK, nobody panic!<br />
There is a bug somewhere that causes a random boot loop to appear in the ESP32 and strangely I had this with a Stamp the other weekend.<br />
Disconnect everything and leave the controllers unconnected for a while, cold boot the computer and try and flash UIFLow firmware.</p>
]]></description><link>https://community.m5stack.com/post/15192</link><guid isPermaLink="true">https://community.m5stack.com/post/15192</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 21 Oct 2021 17:13:17 GMT</pubDate></item><item><title><![CDATA[Reply to Bootloop on Thu, 21 Oct 2021 08:40:31 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/kabron" aria-label="Profile: Kabron">@<bdi>Kabron</bdi></a></p>
<p dir="auto">If you cannot download firmware automatically anymore you'll need to force your M5Stack device into download mode manually. Connect a wire between GPIO0 and GND. Then power on the device. It should now be in download mode:</p>
<pre><code>rst:0x1 (POWERON_RESET),boot:0x0 (DOWNLOAD_BOOT(UART0/UART1/SDIO_FEI_FEO_V2))
waiting for download
<p dir="auto">When you see that output you can remove the wire and proceed to download new firmware.</p>
<p dir="auto">Note: if you do not remove the wire you can still download firmware, but upon resetting the device it will go into manual download mode again instead of running the new firmware.</p>
]]></description><link>https://community.m5stack.com/post/15180</link><guid isPermaLink="true">https://community.m5stack.com/post/15180</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 21 Oct 2021 08:40:31 GMT</pubDate></item></channel></rss>
