<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[may i use esp32 library for M5stack coding?]]></title><description><![CDATA[<p dir="auto">I'm new to M5Stack (and ESP32);  esp32 has firebase library, but M5Stack doesn't; may I use the firebase-esp library to code with my M5Stack Core2? thanks!<br />
In my mind, I think M5Stack is just feature-rich esp32 dev-kit. i did try this but then get a blank screen and have to M5burn it to factory default.</p>
<p dir="auto">Robin</p>
]]></description><link>https://community.m5stack.com/topic/3659/may-i-use-esp32-library-for-m5stack-coding</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 22:35:42 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3659.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 18 Oct 2021 14:11:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to may i use esp32 library for M5stack coding? on Tue, 19 Oct 2021 07:23:54 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/robinjiao" aria-label="Profile: robinJiao">@<bdi>robinJiao</bdi></a></p>
<p dir="auto">you are correct, M5Stack devices are feature rich ESP32 kits. And yes, you most likely can use the firebase-esp library to code for the ESP32 processor in your M5Core2. However the additional hardware, e.g. LCD, touch screen, RTC, accelerometer, etc. in your M5Core2 are not getting initialized automatically since the firebase-esp library doesn't know about them. That is the reason you are seeing a blank screen. (BTW: the firebase-esp code most likely is running though - did you check the serial output?)</p>
<p dir="auto">That said, may I suggest you start with the <a href="https://github.com/m5stack/M5Core2" target="_blank" rel="noopener noreferrer nofollow ugc">libraries</a> designed for M5Core2 and run some simple examples first? My apologies, if you already have done that.</p>
]]></description><link>https://community.m5stack.com/post/15167</link><guid isPermaLink="true">https://community.m5stack.com/post/15167</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Tue, 19 Oct 2021 07:23:54 GMT</pubDate></item></channel></rss>
