<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Is there an RGBW unit for UIFlow?]]></title><description><![CDATA[<p dir="auto">I bought an LED strip from BTF-LIGHTING.  It is based on SK6812, but it has White as well.  It is labeled as RGBW, but the color order is actually G R B W.</p>
<p dir="auto"><a href="https://www.amazon.com/gp/product/B01N2PCIAV/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&amp;psc=1" target="_blank" rel="noopener noreferrer nofollow ugc">RGBW LED Strip</a></p>
<p dir="auto">I would like to use UIFlow for my project.  I tried using the RGB unit blocks in UIFlow, but it gave me unexpected results - probably because of the additional white diode in each neopixel, as well as the different color order.</p>
<p dir="auto">Is there a way to hack the RGB unit to make it work with RGBW and the different color order?  Is there a trick with indexing that will let me address the additional White diodes in each neopixel?  Or is there another unit I can use?  Or a way to make custom blocks that will work with RGBW?</p>
]]></description><link>https://community.m5stack.com/topic/3674/is-there-an-rgbw-unit-for-uiflow</link><generator>RSS for Node</generator><lastBuildDate>Tue, 05 May 2026 11:03:01 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3674.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 23 Oct 2021 13:27:45 GMT</pubDate><ttl>60</ttl></channel></rss>
