<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[WiFi Config help]]></title><description><![CDATA[<p dir="auto">I haven't managed to get the Wifi working with my M5Stack Core2.</p>
<p dir="auto">My modem recognizes the M5 device but I am greeted with a red colored WiFi signal on the device. There is not internet connection happening.</p>
<p dir="auto">Can someone please assist with this screen...</p>
<p dir="auto"><strong>WiFi Cofig</strong><br />
SSID: M5-520<br />
IP: 192.168.4.1</p>
<p dir="auto">Connect this SSID and open the IP in your Browser, enter the WiFi password.</p>
<p dir="auto">My Modem does not recognize 192.168.4.1  It does nothing. My network uses a different IP address. Also, my network has an SSID (network name) so where do I enter this new SSID?</p>
<p dir="auto">Please assist.</p>
]]></description><link>https://community.m5stack.com/topic/3676/wifi-config-help</link><generator>RSS for Node</generator><lastBuildDate>Fri, 01 May 2026 10:52:46 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3676.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 24 Oct 2021 01:33:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to WiFi Config help on Mon, 25 Oct 2021 05:25:43 GMT]]></title><description><![CDATA[<p dir="auto">Are you sure that your computer has connected to the the M5-520 access point using your computers wifi manager?</p>
<p dir="auto">IF you not able to access 192.168.4.1 it means</p>
<li>you are not connected to the M5Stack device,</li>
<li>you may need to refresh the firmware using the M5Burner program.</li>
]]></description><link>https://community.m5stack.com/post/15236</link><guid isPermaLink="true">https://community.m5stack.com/post/15236</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 25 Oct 2021 05:25:43 GMT</pubDate></item><item><title><![CDATA[Reply to WiFi Config help on Mon, 25 Oct 2021 01:01:42 GMT]]></title><description><![CDATA[<p dir="auto">Thanks Flow....but no go!</p>
<p dir="auto">I can confirm the M5stack is connected via WiFi to the modem - that part works OK.<br />
It just does see the Internet.</p>
<p dir="auto">Two questions:</p>
<p dir="auto">In Setup mode "Select WiFi" there is a number appearing which seems to be associated with a WiFi phone I have connected to the same modem. Starts with 09......</p>
<p dir="auto">Any ideas on why that appears on the M5stack and how I can edit it if required?</p>
<p dir="auto">Even when I hard wire into the modem and enter 192.168.4.1 on my Browser, this eventually times out as it doesn't find anything associated with that IP.</p>
<p dir="auto">Thanks</p>
]]></description><link>https://community.m5stack.com/post/15233</link><guid isPermaLink="true">https://community.m5stack.com/post/15233</guid><dc:creator><![CDATA[Flow]]></dc:creator><pubDate>Mon, 25 Oct 2021 01:01:42 GMT</pubDate></item><item><title><![CDATA[Reply to WiFi Config help on Sun, 24 Oct 2021 06:53:54 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/flow" aria-label="Profile: Flow">@<bdi>Flow</bdi></a></p>
<p dir="auto">this screen means that your M5Core2 has started a temporary access point (SSID: M5-520/no password/IP: 192.168.4.1) and is waiting for you to connect to it with a mobile phone, tablet or computer to finish the configuration.</p>
<p dir="auto">When you do that and then use a browser entering 192.168.4.1 you'll be presented with the M5Core2 configuration screen where you can enter the final SSID/password of your own modem/router and confirm. M5Core2 should then reboot and connect to your modem/router.</p>
]]></description><link>https://community.m5stack.com/post/15225</link><guid isPermaLink="true">https://community.m5stack.com/post/15225</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 24 Oct 2021 06:53:54 GMT</pubDate></item></channel></rss>
