<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Create new unit from existing unit?]]></title><description><![CDATA[<p dir="auto">How would I go about creating a new unit from an existing one?</p>
<p dir="auto">I would like a new unit that is similar to the RGB unit.  The new unit will be an RGBW unit, and allow different color orders.  Where is the RGB unit code and how would I go about making a copy, changing the copy, and have the new unit appear in UIFlow?</p>
]]></description><link>https://community.m5stack.com/topic/3686/create-new-unit-from-existing-unit</link><generator>RSS for Node</generator><lastBuildDate>Wed, 06 May 2026 01:28:38 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3686.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 27 Oct 2021 14:15:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Create new unit from existing unit? on Sat, 30 Oct 2021 16:09:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> Thank you.</p>
]]></description><link>https://community.m5stack.com/post/15308</link><guid isPermaLink="true">https://community.m5stack.com/post/15308</guid><dc:creator><![CDATA[bluebulldog]]></dc:creator><pubDate>Sat, 30 Oct 2021 16:09:14 GMT</pubDate></item><item><title><![CDATA[Reply to Create new unit from existing unit? on Sat, 30 Oct 2021 16:08:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> Thank you.</p>
]]></description><link>https://community.m5stack.com/post/15307</link><guid isPermaLink="true">https://community.m5stack.com/post/15307</guid><dc:creator><![CDATA[bluebulldog]]></dc:creator><pubDate>Sat, 30 Oct 2021 16:08:41 GMT</pubDate></item><item><title><![CDATA[Reply to Create new unit from existing unit? on Wed, 27 Oct 2021 16:35:15 GMT]]></title><description><![CDATA[<p dir="auto">You would need to create a new Micropython Library, copy it to the controller and then call it in code.<br />
If you wanted visuals blocks then you would also need to code the new blocks using the custom blocks manager.</p>
]]></description><link>https://community.m5stack.com/post/15260</link><guid isPermaLink="true">https://community.m5stack.com/post/15260</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 27 Oct 2021 16:35:15 GMT</pubDate></item><item><title><![CDATA[Reply to Create new unit from existing unit? on Wed, 27 Oct 2021 16:00:49 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/bluebulldog" aria-label="Profile: bluebulldog">@<bdi>bluebulldog</bdi></a></p>
<p dir="auto">AFAIK UIFlow source code is not available as open source, so I am afraid you'll need to start from scratch.</p>
]]></description><link>https://community.m5stack.com/post/15257</link><guid isPermaLink="true">https://community.m5stack.com/post/15257</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 27 Oct 2021 16:00:49 GMT</pubDate></item></channel></rss>
