<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Unit V2 MQTT support]]></title><description><![CDATA[<p dir="auto">how can I get a MQTT support for the Unit V2. Is it possible to remotely control the Unit V2 functionality like with JSON?<br />
Where can a get the MQTT Jupiter page?<br />
Thanks a lot</p>
]]></description><link>https://community.m5stack.com/topic/3690/unit-v2-mqtt-support</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 06:42:20 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3690.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 28 Oct 2021 15:31:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Unit V2 MQTT support on Mon, 17 Jan 2022 20:28:41 GMT]]></title><description><![CDATA[<p dir="auto">I just received my Unit V2 and was wondering the same about running MQTT. Doing some digging on the chip and I found they already include the mosquito broker, and it works right out of the box.</p>
<p dir="auto">I also got the wpa_supplicant to connect this device to an ssid of my network. Now the device can just startup without the serial wire.</p>
<p dir="auto">Has anyone connected the existing <a href="http://server.py" target="_blank" rel="noopener noreferrer nofollow ugc">server.py</a> code to MQTT or other interfaces?</p>
<p dir="auto">Is the best approach just to modify the <a href="http://server.py" target="_blank" rel="noopener noreferrer nofollow ugc">server.py</a> code to start performing the additional operations, like publishing the JSON data over MQTT?</p>
<p dir="auto">thanks.</p>
]]></description><link>https://community.m5stack.com/post/16241</link><guid isPermaLink="true">https://community.m5stack.com/post/16241</guid><dc:creator><![CDATA[konacurrents]]></dc:creator><pubDate>Mon, 17 Jan 2022 20:28:41 GMT</pubDate></item><item><title><![CDATA[Reply to Unit V2 MQTT support on Fri, 29 Oct 2021 01:48:06 GMT]]></title><description><![CDATA[<ol>
<li>
<p dir="auto">configure wifi connect. <a href="https://docs.m5stack.com/en/quick_start/unitv2/config" target="_blank" rel="noopener noreferrer nofollow ugc">tutorial</a></p>
</li>
<li>
<p dir="auto">run some MQTT python script</p>
</li>
<p dir="auto">such like:</p>
<p dir="auto"><a href="https://www.emqx.com/en/blog/how-to-use-mqtt-in-python" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.emqx.com/en/blog/how-to-use-mqtt-in-python</a></p>
]]></description><link>https://community.m5stack.com/post/15277</link><guid isPermaLink="true">https://community.m5stack.com/post/15277</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Fri, 29 Oct 2021 01:48:06 GMT</pubDate></item></channel></rss>
