<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[VIbrator Motor Unit not working correctly]]></title><description><![CDATA[<p dir="auto">Hello!</p>
<p dir="auto">I just bought a bunch of Vibrator Motor Units and none of them is working correctly :/ When I plug them i can hear a little soung from the motor but the metal piece does not move.</p>
<p dir="auto">Sometimes (after setting the Vibrator on duty on 20 in the UI Flor for instance) the metal piece starts working after a little push with the finger. But it's very light and not really vibrating.<br />
Does someone know why ?</p>
<p dir="auto">I saw on the product page that there is an EasyLoader, but as I'm on Linux I can not try it. Is it the answer?</p>
<p dir="auto">Many thanks,<br />
Thomas</p>
]]></description><link>https://community.m5stack.com/topic/3692/vibrator-motor-unit-not-working-correctly</link><generator>RSS for Node</generator><lastBuildDate>Fri, 01 May 2026 06:24:24 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3692.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 28 Oct 2021 15:39:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to VIbrator Motor Unit not working correctly on Fri, 05 Nov 2021 09:09:44 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/dailletaille" aria-label="Profile: dailletaille">@<bdi>dailletaille</bdi></a></p>
<p dir="auto">glad it worked. Thank you for reporting back. My guess is something's wrong with the UIFlow block - it would not be the first time.</p>
<p dir="auto">BTW: the GPIO output is not directly connected to the motor; there is a MOSFET in between to translate between 3.3 V and 5 V. But 0.5 V is definitely too low for it to fully switch on. See <a href="https://docs.m5stack.com/en/unit/vibrator" target="_blank" rel="noopener noreferrer nofollow ugc">schematic</a> here.</p>
]]></description><link>https://community.m5stack.com/post/15366</link><guid isPermaLink="true">https://community.m5stack.com/post/15366</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 05 Nov 2021 09:09:44 GMT</pubDate></item><item><title><![CDATA[Reply to VIbrator Motor Unit not working correctly on Fri, 05 Nov 2021 08:18:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> oh! I didn't know about this <code>Easy I/O</code> node. I'll try that and let you know how it went. Thanks a looot<br />
EDIT : I just tried it and it worked like a charm! thank you so much. Above the red pin of the motor, it is written "5V". So no wonder it didn't worked as expected with 0,5V :/ Maybe we could point this out to someone at M5 so they can solve this?<br />
<img src="/assets/uploads/files/1636100257942-0aad87d8-3df7-46e4-8e9f-b689b5c96959-image-resized.png" alt="0_1636100256085_0aad87d8-3df7-46e4-8e9f-b689b5c96959-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/15363</link><guid isPermaLink="true">https://community.m5stack.com/post/15363</guid><dc:creator><![CDATA[dailletaille]]></dc:creator><pubDate>Fri, 05 Nov 2021 08:18:03 GMT</pubDate></item><item><title><![CDATA[Reply to VIbrator Motor Unit not working correctly on Thu, 04 Nov 2021 18:12:38 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/dailletaille" aria-label="Profile: dailletaille">@<bdi>dailletaille</bdi></a></p>
<p dir="auto">I don't know if something's broken in UIFlow or not properly adapted to M5Stick and I don't own a vibration motor unit. But using the <code>Set vibrator0 on by duty 100</code> block I only measure about 0.5 V at GPIO32 which controls the speed of the motor. This seems much to low to me. I'd expect 3.3 V at max. duty cycle.</p>
<p dir="auto">That said, you could try and use the <code>Hardwares</code> -  <code>Easy I/O</code> - <code>analog write pin 32 duty 100</code> instead. This should give you full throttle.</p>
]]></description><link>https://community.m5stack.com/post/15358</link><guid isPermaLink="true">https://community.m5stack.com/post/15358</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 04 Nov 2021 18:12:38 GMT</pubDate></item><item><title><![CDATA[Reply to VIbrator Motor Unit not working correctly on Thu, 04 Nov 2021 15:46:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> Hey :) I've tried different values (including 100) and none of them worked :/</p>
]]></description><link>https://community.m5stack.com/post/15356</link><guid isPermaLink="true">https://community.m5stack.com/post/15356</guid><dc:creator><![CDATA[dailletaille]]></dc:creator><pubDate>Thu, 04 Nov 2021 15:46:40 GMT</pubDate></item><item><title><![CDATA[Reply to VIbrator Motor Unit not working correctly on Thu, 04 Nov 2021 15:48:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> hello Felix thanks for your answer!<br />
I'm using a M5StickC. I try to plug it to my computer and to a power socket, it doesn't change anything :/<br />
the UIFlow code is a very simple test code:<br />
<img src="/assets/uploads/files/1636040693905-screenshot-2021-11-04-at-16-43-58-m5flow.png" alt="0_1636040693532_Screenshot 2021-11-04 at 16-43-58 M5Flow.png" class=" img-fluid img-markdown" /><br />
And no I didn't tried Arduino example, what is it?</p>
]]></description><link>https://community.m5stack.com/post/15355</link><guid isPermaLink="true">https://community.m5stack.com/post/15355</guid><dc:creator><![CDATA[dailletaille]]></dc:creator><pubDate>Thu, 04 Nov 2021 15:48:00 GMT</pubDate></item><item><title><![CDATA[Reply to VIbrator Motor Unit not working correctly on Thu, 28 Oct 2021 19:48:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dailletaille" aria-label="Profile: dailletaille">@<bdi>dailletaille</bdi></a> 20?<br />
I'm sure it needs to be 100 but don't know the exact range</p>
]]></description><link>https://community.m5stack.com/post/15274</link><guid isPermaLink="true">https://community.m5stack.com/post/15274</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 28 Oct 2021 19:48:46 GMT</pubDate></item><item><title><![CDATA[Reply to VIbrator Motor Unit not working correctly on Thu, 28 Oct 2021 17:55:57 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/dailletaille" aria-label="Profile: dailletaille">@<bdi>dailletaille</bdi></a></p>
<li>which M5Stack device are you using?</li>
<li>how do you power it?</li>
<li>could you share the UIFlow code?</li>
<li>have you tried the Arduino example?</li>
]]></description><link>https://community.m5stack.com/post/15273</link><guid isPermaLink="true">https://community.m5stack.com/post/15273</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 28 Oct 2021 17:55:57 GMT</pubDate></item></channel></rss>
