<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Stamp pico min max V]]></title><description><![CDATA[<p dir="auto">Hi all. Can anybody tell me which is the minimum and the maximum allowed voltage for Pico Stamp? I see it has a 5V DC DC so I was wondering if it can accept a lower voltage.</p>
<p dir="auto">I’m designing the electric circuit in my new house and I was thinking to have cables with either 5v or 12v in every room wherever I will need an ESP32. So I was calculating the necessary cable diameter for 5V @ 500mA and the relative accepted voltage drop (cables will be up to 10-13mt long).</p>
<p dir="auto">Thank you.</p>
]]></description><link>https://community.m5stack.com/topic/3698/stamp-pico-min-max-v</link><generator>RSS for Node</generator><lastBuildDate>Tue, 05 May 2026 18:32:45 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3698.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 30 Oct 2021 10:02:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Stamp pico min max V on Mon, 01 Nov 2021 18:59:25 GMT]]></title><description><![CDATA[<p dir="auto">工作电压/供电电压 3.0 V ~ 3.6 V<br />
Operating voltage/supply voltage 3.0 V ~ 3.6 V</p>
]]></description><link>https://community.m5stack.com/post/15333</link><guid isPermaLink="true">https://community.m5stack.com/post/15333</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 01 Nov 2021 18:59:25 GMT</pubDate></item><item><title><![CDATA[Reply to Stamp pico min max V on Sun, 31 Oct 2021 16:52:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> if the margin above 3.3V is somehow related to the Feedback Reference Voltage than the datasheet confirms it’s 0.6V. That should be no problem as I think I’ll stay above 4.5V. Regarding the capacitor thanks for the hint, I’ll keep in mind that. I’m somehow limited in space but I believe it would be no problem finding something small to be connected on the cables just before the Stamp. Thanks again for the inputs.</p>
]]></description><link>https://community.m5stack.com/post/15320</link><guid isPermaLink="true">https://community.m5stack.com/post/15320</guid><dc:creator><![CDATA[zahari4i]]></dc:creator><pubDate>Sun, 31 Oct 2021 16:52:58 GMT</pubDate></item><item><title><![CDATA[Reply to Stamp pico min max V on Sun, 31 Oct 2021 11:10:17 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/zahari4i" aria-label="Profile: zahari4i">@<bdi>zahari4i</bdi></a></p>
<p dir="auto">please keep in mind that the used IC only is a <strong>step-down</strong> DC-DC converter. This means the input voltage needs to be <strong>above</strong> the output voltage. By how much I couldn't figure out from the datasheet though. I'd suspect something like 0.6 V. So for an output voltage of 3.3 V you probably need at least 3.9 V input voltage. If you go lower the output voltage will go lower as well.</p>
<p dir="auto">Also keep in mind that the ESP32 have a rather high peek current, especially when doing WiFi stuff. I'd plan on adding some capacitor close to each device to cover for that.</p>
]]></description><link>https://community.m5stack.com/post/15318</link><guid isPermaLink="true">https://community.m5stack.com/post/15318</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 31 Oct 2021 11:10:17 GMT</pubDate></item><item><title><![CDATA[Reply to Stamp pico min max V on Sun, 31 Oct 2021 10:25:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> some empirical evidence would be great, whenever you have time to check it. Thank you</p>
]]></description><link>https://community.m5stack.com/post/15317</link><guid isPermaLink="true">https://community.m5stack.com/post/15317</guid><dc:creator><![CDATA[zahari4i]]></dc:creator><pubDate>Sun, 31 Oct 2021 10:25:33 GMT</pubDate></item><item><title><![CDATA[Reply to Stamp pico min max V on Sun, 31 Oct 2021 10:24:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> thanks a lot. From the datasheet I see a range of 2.7 to 6.5V. So basically I have no problems going even lower than 4 volts. That’s great news! Thank you!</p>
]]></description><link>https://community.m5stack.com/post/15316</link><guid isPermaLink="true">https://community.m5stack.com/post/15316</guid><dc:creator><![CDATA[zahari4i]]></dc:creator><pubDate>Sun, 31 Oct 2021 10:24:45 GMT</pubDate></item><item><title><![CDATA[Reply to Stamp pico min max V on Sun, 31 Oct 2021 08:04:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/zahari4i" aria-label="Profile: zahari4i">@<bdi>zahari4i</bdi></a> Sorry, my bench supply isn't working yet and so I get test to see how low the stamp will go.</p>
]]></description><link>https://community.m5stack.com/post/15314</link><guid isPermaLink="true">https://community.m5stack.com/post/15314</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 31 Oct 2021 08:04:00 GMT</pubDate></item><item><title><![CDATA[Reply to Stamp pico min max V on Sun, 31 Oct 2021 07:57:31 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/zahari4i" aria-label="Profile: zahari4i">@<bdi>zahari4i</bdi></a></p>
<p dir="auto">well, on the schematic you'll find the DC-DC converter (SY8079AAAC) - its datasheet should help you getting the info you're looking for.</p>
]]></description><link>https://community.m5stack.com/post/15313</link><guid isPermaLink="true">https://community.m5stack.com/post/15313</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 31 Oct 2021 07:57:31 GMT</pubDate></item><item><title><![CDATA[Reply to Stamp pico min max V on Sun, 31 Oct 2021 07:52:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> what about feeding it lower voltage at 5V. I read it has a DC DC incorporated so I was wondering what tolerance it has. Depending on the distance I will sometimes have 5, 4.9,4.6 volts. The lowest I’ll go as per my calculations is 4.6V.<br />
Do you think this would be enough to safely power the stamp?</p>
]]></description><link>https://community.m5stack.com/post/15312</link><guid isPermaLink="true">https://community.m5stack.com/post/15312</guid><dc:creator><![CDATA[zahari4i]]></dc:creator><pubDate>Sun, 31 Oct 2021 07:52:52 GMT</pubDate></item><item><title><![CDATA[Reply to Stamp pico min max V on Sun, 31 Oct 2021 07:49:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> hi yes, not very good at reading schematics but I wasn’t able to find anything else other than the fact it needs 5v 500 mA. Am I missing something?</p>
]]></description><link>https://community.m5stack.com/post/15311</link><guid isPermaLink="true">https://community.m5stack.com/post/15311</guid><dc:creator><![CDATA[zahari4i]]></dc:creator><pubDate>Sun, 31 Oct 2021 07:49:25 GMT</pubDate></item><item><title><![CDATA[Reply to Stamp pico min max V on Sat, 30 Oct 2021 14:59:21 GMT]]></title><description><![CDATA[<p dir="auto">the ESP32 runs on 3v3 but the stamp modules uses 5V input<br />
The 3v3 pin used by the programmer pin can be used to provide a 3v3 input but sometimes I have found the stamp will crash.</p>
]]></description><link>https://community.m5stack.com/post/15304</link><guid isPermaLink="true">https://community.m5stack.com/post/15304</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 30 Oct 2021 14:59:21 GMT</pubDate></item><item><title><![CDATA[Reply to Stamp pico min max V on Sat, 30 Oct 2021 13:03:32 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/zahari4i" aria-label="Profile: zahari4i">@<bdi>zahari4i</bdi></a></p>
<p dir="auto">have looked at the <a href="https://docs.m5stack.com/en/core/stamp_pico" target="_blank" rel="noopener noreferrer nofollow ugc">schematic</a>?</p>
]]></description><link>https://community.m5stack.com/post/15302</link><guid isPermaLink="true">https://community.m5stack.com/post/15302</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sat, 30 Oct 2021 13:03:32 GMT</pubDate></item></channel></rss>
