<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Atom + tailbat battery not waking up after deepsleep]]></title><description><![CDATA[<p dir="auto">Using esphome, I configured an Atom Lite with deepsleep and while I keep it connected to the laptop with the logging terminal open, I can see the device staying awake as per my configuration:</p>
<p dir="auto">deep_sleep:<br />
run_duration: 120s<br />
sleep_duration: 10min</p>
<p dir="auto">... and going to sleep for 10min, then waking up etc.</p>
<p dir="auto">When I plug the tailbat battery, I can see the device stays awake as per the configuration, then it goes into deep sleep, and it never wakes up. I see the red LED in the battery going off after the "run_duration" timer expires. It seems as if the atom lite is "turning off" the battery, it's a bit strange.</p>
<p dir="auto">Any hint on how to keep the battery on while the atom is on deep sleep?</p>
]]></description><link>https://community.m5stack.com/topic/3710/atom-tailbat-battery-not-waking-up-after-deepsleep</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 11:36:34 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3710.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 05 Nov 2021 01:12:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Atom + tailbat battery not waking up after deepsleep on Fri, 05 Nov 2021 06:57:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ar" aria-label="Profile: ar">@<bdi>ar</bdi></a> This is the power chip in the battery powering off due to lack of demand from the atom. you could put a resistor across the power lines to keep a load on the tail bat but that would defeat the energy saving requirements of deep sleep.</p>
]]></description><link>https://community.m5stack.com/post/15362</link><guid isPermaLink="true">https://community.m5stack.com/post/15362</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 05 Nov 2021 06:57:23 GMT</pubDate></item></channel></rss>
