<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Core2 A2DP Source]]></title><description><![CDATA[<p dir="auto">I thought it would be cool to make an MP3 player using the Core2. Thought it would be a walk in the park.<br />
To my surprise Arduino has no support for bluetooth A2DP Source. ESP-ADF does. So I can't work with Arduino, and I cant work with ESP-IDF because Stack5 is so out of date with it's M5Stack-IDF.<br />
I can't be the only one who want to use BT to connect to an external BT speaker.</p>
<p dir="auto">Why is M5Stack, so behind with it's M5Stack-IDF ?</p>
]]></description><link>https://community.m5stack.com/topic/3725/core2-a2dp-source</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 04:47:32 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3725.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 10 Nov 2021 02:45:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Core2 A2DP Source on Sun, 15 May 2022 15:26:19 GMT]]></title><description><![CDATA[<p dir="auto"><a href="https://github.com/pschatzmann/ESP32-A2DP" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/pschatzmann/ESP32-A2DP</a></p>
]]></description><link>https://community.m5stack.com/post/17490</link><guid isPermaLink="true">https://community.m5stack.com/post/17490</guid><dc:creator><![CDATA[riraosan]]></dc:creator><pubDate>Sun, 15 May 2022 15:26:19 GMT</pubDate></item><item><title><![CDATA[Reply to Core2 A2DP Source on Wed, 10 Nov 2021 12:35:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> said in <a href="/post/15422">Core2 A2DP Source</a>:</p>
<p dir="auto">M5Stack devices are built on the ESP32 and so you can go strait to ESP-IDF/ESP-ADF and program them directly.</p>
<p dir="auto">True, but there is a hitch. M5Stack-IDF is over 2 years old now. I will loose to much functionality going that route.</p>
<p dir="auto">I spent all last night setting ESP-IDF up on a RPI4 and still did not complete it.</p>
<p dir="auto">That is probably a good thing, on a RPI it would probably take like 10 minutes to compile.</p>
]]></description><link>https://community.m5stack.com/post/15424</link><guid isPermaLink="true">https://community.m5stack.com/post/15424</guid><dc:creator><![CDATA[mikemoy]]></dc:creator><pubDate>Wed, 10 Nov 2021 12:35:02 GMT</pubDate></item><item><title><![CDATA[Reply to Core2 A2DP Source on Wed, 10 Nov 2021 07:23:16 GMT]]></title><description><![CDATA[<p dir="auto">UIflow/micropython is the main programming environment for programming M5Stack devices however, M5Stack devices are built on the ESP32 and so you can go strait to ESP-IDF/ESP-ADF and program them directly.</p>
<p dir="auto">Unless you have decades of programming experience, programming is never going to "be a walk in the park"</p>
]]></description><link>https://community.m5stack.com/post/15422</link><guid isPermaLink="true">https://community.m5stack.com/post/15422</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 10 Nov 2021 07:23:16 GMT</pubDate></item></channel></rss>
