<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Measuring energy consumption with M5stack basic]]></title><description><![CDATA[<p dir="auto">HI everyone ! I have bought M5stack with the objective of connect with INA226 and measure energy consumption. I have read the article on digikey <a href="https://www.digikey.com/en/maker/projects/use-m5stack-to-measure-power-consumption/00d20499f5e047fe86ab310cce0cb0c1" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.digikey.com/en/maker/projects/use-m5stack-to-measure-power-consumption/00d20499f5e047fe86ab310cce0cb0c1</a> .<br />
Anyway it is not clear to me which program to run on M5stack in order to measure energy consumption. There is not any info on this article. Can you please suggest me or give a tip ?<br />
Thank you very much.<br />
Bye</p>
]]></description><link>https://community.m5stack.com/topic/3730/measuring-energy-consumption-with-m5stack-basic</link><generator>RSS for Node</generator><lastBuildDate>Thu, 07 May 2026 19:10:06 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3730.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 11 Nov 2021 16:31:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Measuring energy consumption with M5stack basic on Fri, 19 Nov 2021 14:31:37 GMT]]></title><description><![CDATA[<p dir="auto">Thank You Felmue.<br />
The source code that is mentioned in the post you linked should be run in arduino ? Thank you</p>
]]></description><link>https://community.m5stack.com/post/15523</link><guid isPermaLink="true">https://community.m5stack.com/post/15523</guid><dc:creator><![CDATA[robertobruzzese]]></dc:creator><pubDate>Fri, 19 Nov 2021 14:31:37 GMT</pubDate></item><item><title><![CDATA[Reply to Measuring energy consumption with M5stack basic on Thu, 11 Nov 2021 16:48:43 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/robertobruzzese" aria-label="Profile: robertobruzzese">@<bdi>robertobruzzese</bdi></a></p>
<p dir="auto">Google is your friend. The article you mentioned is also <a href="https://m5stack.hackster.io/ghibi/use-m5stack-to-measure-power-consumption-7ca1ff" target="_blank" rel="noopener noreferrer nofollow ugc">here</a> - including source code. Have fun!</p>
]]></description><link>https://community.m5stack.com/post/15438</link><guid isPermaLink="true">https://community.m5stack.com/post/15438</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 11 Nov 2021 16:48:43 GMT</pubDate></item></channel></rss>
