<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Core 2 Device and UIFlow updates using Wifi with a running app?]]></title><description><![CDATA[<p dir="auto">I'm new to M5Stack development and facing an issue with the UIFlow code upload into my M5stack Core2 device. When doing a fresh firmware burn from "M5 Burner", I'm able to watch a successful (green) connection with the server. Once the main application is loaded, then I’m not able anymore to synchronize the Core2 device using Wifi. I’ve tried several procedures like pressing  the "C" button but the device is not returning into a network setup mode. Indeed the application starts too quickly to get into the network menu. I’ve validated the APIkey, its OK. Any help how to connect the UIFlow server in order to upload latest application updates, without need of loading a fresh firmware at every update?</p>
]]></description><link>https://community.m5stack.com/topic/3731/core-2-device-and-uiflow-updates-using-wifi-with-a-running-app</link><generator>RSS for Node</generator><lastBuildDate>Sat, 09 May 2026 13:50:34 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3731.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 11 Nov 2021 17:47:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Core 2 Device and UIFlow updates using Wifi with a running app? on Fri, 12 Nov 2021 15:44:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> Thanks for the detailed instructions. Now able to handle it.</p>
]]></description><link>https://community.m5stack.com/post/15450</link><guid isPermaLink="true">https://community.m5stack.com/post/15450</guid><dc:creator><![CDATA[falbriard]]></dc:creator><pubDate>Fri, 12 Nov 2021 15:44:02 GMT</pubDate></item><item><title><![CDATA[Reply to Core 2 Device and UIFlow updates using Wifi with a running app? on Thu, 11 Nov 2021 18:28:27 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/falbriard" aria-label="Profile: falbriard">@<bdi>falbriard</bdi></a></p>
<p dir="auto">yes, after a <code>Download</code> the M5Core2 automatically switches from <code>Internet mode</code> to <code>App mode</code> and as long as it is in this mode it doesn't connect to the UIFlow server anymore, but runs the downloaded program. Try using <code>Run</code> from UIFlow instead. This should temporarily download and run your program, but stay connected to UIFlow server. Then only when you're happy and want to permanently install your program use <code>Download</code>.</p>
<p dir="auto">To go back to <code>Internet mode</code> on M5Core2 is a pain, I agree. Next to the (too) short time the menu shows I suspect that the active touch areas are too small and therefore hard to hit properly.</p>
<p dir="auto">As an alternative to switch modes, have you tried the <code>Configuration</code> button in M5Burner? It should allow you to switch back to <code>Internet mode</code> as well (w/o the need to redownload UIFlow firmware).</p>
]]></description><link>https://community.m5stack.com/post/15443</link><guid isPermaLink="true">https://community.m5stack.com/post/15443</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 11 Nov 2021 18:28:27 GMT</pubDate></item></channel></rss>
