<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[LORA-MODULE-868MHZ and LoRaWAN]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I am using LORA-MODULE-868MHZ with LMIC stack for a device in a LoRaWAN network.</p>
<p dir="auto">I successfully join the network. It sends three packets and then nothing else.</p>
<p dir="auto">My pinmap seems correct.</p>
<p dir="auto">But if I look at the scematic below, DIOx are <strong>not</strong> connected...</p>
<p dir="auto">So my guess is that we can not do LoRaWAN with this module but only "raw LoRa".</p>
<p dir="auto">Am I right ? It is not clear in the documentation.</p>
<p dir="auto">Thanks.</p>
<p dir="auto"><img src="/assets/uploads/files/1636718296714-3d5258da-8051-487c-8963-68f93ae04a71-image.png" alt="0_1636718294962_3d5258da-8051-487c-8963-68f93ae04a71-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/topic/3735/lora-module-868mhz-and-lorawan</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 07:08:57 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3735.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 12 Nov 2021 11:59:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to LORA-MODULE-868MHZ and LoRaWAN on Fri, 12 Nov 2021 19:57:03 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/remaille" aria-label="Profile: remaille">@<bdi>remaille</bdi></a></p>
<p dir="auto">it should work with LoRaWAN, but as you already mentioned DIO1 needs to be connected to a GPIO on the M-Bus. I found this <a href="https://www.bjoerns-techblog.de/2020/12/m5stack-lora-868-modul/" target="_blank" rel="noopener noreferrer nofollow ugc">article</a> (sorry, it's in German).</p>
]]></description><link>https://community.m5stack.com/post/15455</link><guid isPermaLink="true">https://community.m5stack.com/post/15455</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 12 Nov 2021 19:57:03 GMT</pubDate></item></channel></rss>
