<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Core2 kmbusmode]]></title><description><![CDATA[<p dir="auto">When I use m5stack core2 with mbus as Input and 5v input, serial2 does not work and the microcontroller shuts down. m5stack core2 with mbus as Output and 5v input to BAT pin works <a href="http://fine.Is" target="_blank" rel="noopener noreferrer nofollow ugc">fine.Is</a> there a problem if I use 5V input to the BAT pin of m5stack core2?</p>
]]></description><link>https://community.m5stack.com/topic/3739/core2-kmbusmode</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 09:01:39 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3739.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 14 Nov 2021 05:15:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Core2 kmbusmode on Sun, 14 Nov 2021 11:15:11 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/mu0104" aria-label="Profile: mu0104">@<bdi>mu0104</bdi></a></p>
<p dir="auto">that doesn't sound right. I have an M5Core2 which is solely powered via the 5 V input from the stacked COM.X module and the communication between the two uses Serial2 (aka GPIO13 and GPIO14) successfully.</p>
<p dir="auto">Do you care to share your code?</p>
]]></description><link>https://community.m5stack.com/post/15467</link><guid isPermaLink="true">https://community.m5stack.com/post/15467</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 14 Nov 2021 11:15:11 GMT</pubDate></item></channel></rss>
