<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Porting code from M5StickC to new Plus version]]></title><description><![CDATA[<p dir="auto">Hi out there. For the elder M5StickC (without Plus) I wrote several applications using the old small display. Unfortunately the elder stick (with the small display)<br />
isnt longer avaliable so I have to switch to the new PLUS version. Although M5 says that the Plus version is fully compatible, the graphics dont work<br />
properly. Sure it cannot cause of the larger display. Is there any possibility to make my code compatible without re-writing all (dont need that<br />
bigger display) ? Thanks for any idea.<br />
Regards Peter</p>
]]></description><link>https://community.m5stack.com/topic/3744/porting-code-from-m5stickc-to-new-plus-version</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 01:00:35 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3744.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 15 Nov 2021 15:11:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Porting code from M5StickC to new Plus version on Tue, 16 Nov 2021 16:27:36 GMT]]></title><description><![CDATA[<p dir="auto">Thanks Felix for the hint. Will try that and report about ...<br />
Regards<br />
Peter</p>
]]></description><link>https://community.m5stack.com/post/15494</link><guid isPermaLink="true">https://community.m5stack.com/post/15494</guid><dc:creator><![CDATA[DG4EK]]></dc:creator><pubDate>Tue, 16 Nov 2021 16:27:36 GMT</pubDate></item><item><title><![CDATA[Reply to Porting code from M5StickC to new Plus version on Tue, 16 Nov 2021 08:01:05 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/dg4ek" aria-label="Profile: DG4EK">@<bdi>DG4EK</bdi></a></p>
<p dir="auto">I'd start by replacing the M5StickC with the M5StickCPlus library and then include <code>M5StickCPlus.h</code> instead of <code>M5StickC.h</code> in your program. Then see what breaks (if anything) and fix that.</p>
]]></description><link>https://community.m5stack.com/post/15488</link><guid isPermaLink="true">https://community.m5stack.com/post/15488</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Tue, 16 Nov 2021 08:01:05 GMT</pubDate></item></channel></rss>
