<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Powering SKU: U111 NB-IoT Unit]]></title><description><![CDATA[<p dir="auto">Hello,<br />
Your SKU: U111 NB-IoT Unit is specified to have 5V input. I guess that is for both power and io pins.</p>
<p dir="auto">I try to operate this device by feeding with 3V. (both power and  io pins). This seems to work just fine.</p>
<p dir="auto">Is it ok to power this device with 3V ? or should this be avoided ?</p>
<p dir="auto">Best regards<br />
Håvard</p>
]]></description><link>https://community.m5stack.com/topic/3745/powering-sku-u111-nb-iot-unit</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 09:04:10 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3745.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 15 Nov 2021 15:25:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Powering SKU: U111 NB-IoT Unit on Mon, 15 Nov 2021 17:24:27 GMT]]></title><description><![CDATA[<p dir="auto">Hello @haavard-holm</p>
<p dir="auto">most (if not all) units have a 5 V input. Internally there often is a power regulator to 3.3 V or whatever voltage the ICs used in the unit requires. The signal lines are 3.3 V as they are connected directly to GPIOs of the ESP32 which is 3.3 V too. If the data lines of the IC in the unit have an even lower voltage level shifters are put in place.</p>
<p dir="auto">The input voltage of the regulator is 2.7 V to 5.5 V. The minimal voltage drop between input and output is about 0.6 V for these regulators. So if you feed it with 3.3 V I'd guess the output voltage to be about 2.7 V.</p>
<p dir="auto">According to its datasheet the SIM7020 IC has an operating voltage range from 2.1 V to 3.6V so you should be fine. Its data lines are 1.8 V which are then level shifted to the output voltage of the regulator (e.g. 2.7 V) which should still be high enough for the ESP32 GPIOs to recognize properly.</p>
]]></description><link>https://community.m5stack.com/post/15481</link><guid isPermaLink="true">https://community.m5stack.com/post/15481</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Mon, 15 Nov 2021 17:24:27 GMT</pubDate></item></channel></rss>
