<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ATOM RS-485 - No power via USB]]></title><description><![CDATA[<p dir="auto">I've been using the ATOM RS-485n kit (<a href="https://docs.m5stack.com/en/atom/atomic485" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/en/atom/atomic485</a>) to connect to an electricity meter using ESPHome. Last night this was working with the A/B wires connected to the meter and the ATOM lite powered via the USB connection to my laptop.</p>
<p dir="auto">Today, for some reason, if I plug the ATOM lite into the RS485 unit then it won't power at all via USB whether or not the A/B wires are connected. I must be doing something different, but for the life of me can't work out what is different.</p>
<p dir="auto">Should I expect to be able to power it by USB? Is there something I might have done (software or hardware) that would stop that happening. The ATOM lite is still working - if I connect it without the RS-485 base then it works exactly as expected.</p>
<p dir="auto">Any suggestions very welcome!</p>
<p dir="auto">Andrew</p>
]]></description><link>https://community.m5stack.com/topic/3766/atom-rs-485-no-power-via-usb</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 11:36:33 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3766.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 21 Nov 2021 19:27:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ATOM RS-485 - No power via USB on Sun, 28 Nov 2021 21:06:59 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/watchforstock" aria-label="Profile: watchforstock">@<bdi>watchforstock</bdi></a></p>
<p dir="auto">looking at the ATOM RS485 schematic the only way I see which would keep the M5Atom from powering up when plugged into the ATOM RS485 is if somehow the 5 V line is (partly) shorted to GND.</p>
<p dir="auto">Now, there is a built-in DC-DC converter in the ATOM RS485 converting the input voltage from the RS485 connector to 5 V. In your case however this DC-DC converter is not fed an input voltage. Maybe the DC-DC converter IC didn't like the fact it was fed 5 V into its output from the M5Atom.</p>
<p dir="auto">You could try to measure the 5 V on the Groove connector while the M5Atom is plugged into the ATOM RS485 to see if it somehow is pulled down.</p>
]]></description><link>https://community.m5stack.com/post/15650</link><guid isPermaLink="true">https://community.m5stack.com/post/15650</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 28 Nov 2021 21:06:59 GMT</pubDate></item></channel></rss>
