<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Using Grove - RGB LED Stick with ATOM Matrix?]]></title><description><![CDATA[<p dir="auto">Hello, any tips on how to use <a href="https://www.seeedstudio.com/Grove-RGB-LED-Stick-15-WS2813-Mini-p-4270.html" target="_blank" rel="noopener noreferrer nofollow ugc">this grove LED stick</a>? I tried the example on <a href="https://wiki.seeedstudio.com/Grove-RGB_LED_Stick-10-WS2813_Mini/" target="_blank" rel="noopener noreferrer nofollow ugc">wiki</a> with pins 26 and 32 (from docs on ATOM), various brightness levels, but nothing really works. It always crashes. Only modifications I did to the example were changing the pin, brightness and adding <code>M5.begin(true, true, true);</code>.</p>
<pre><code>Guru Meditation Error: Core  1 panic'ed (Interrupt wdt timeout on CPU1)
Core 1 register dump:
PC      : 0x40081117  PS      : 0x00050034  A0      : 0x400841ec  A1      : 0x3ffbeba0
A2      : 0x00000002  A3      : 0x3ff56000  A4      : 0x01000000  A5      : 0x00000001
A6      : 0x0000001a  A7      : 0x3ffbff48  A8      : 0x00000001  A9      : 0x3ffbd6a0
A10     : 0x00000000  A11     : 0x00000000  A12     : 0x00060023  A13     : 0x3ffbc22c
A14     : 0x00000000  A15     : 0x00000000  SAR     : 0x00000018  EXCCAUSE: 0x00000006
EXCVADDR: 0x00000000  LBEG    : 0x00000000  LEND    : 0x00000000  LCOUNT  : 0x00000000
Core 1 was running in ISR context:
EPC1    : 0x400e35ca  EPC2    : 0x00000000  EPC3    : 0x400ecfca  EPC4    : 0x40081117
ELF file SHA256: 0000000000000000
Backtrace: 0x40081117:0x3ffbeba0 0x400841e9:0x3ffbebc0 0x400ecfc7:0x3ffbc6b0 0x400e35c7:0x3ffbc6d0 0x400889ea:0x3ffbc6f0 0x400874f5:0x3ffbc710
<p dir="auto">I tried some I2C scanner (don't really know, how it works) and only device it lists is 0x68. Since it does show it even after disconnecting the LED strip, I guess it's something integrated and not the LED strip? I am quite new to this, so it's probably something silly...</p>
]]></description><link>https://community.m5stack.com/topic/3769/using-grove-rgb-led-stick-with-atom-matrix</link><generator>RSS for Node</generator><lastBuildDate>Wed, 13 May 2026 04:15:29 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3769.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 23 Nov 2021 13:49:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Using Grove - RGB LED Stick with ATOM Matrix? on Thu, 25 Nov 2021 12:52:46 GMT]]></title><description><![CDATA[<p dir="auto">Got it to work 😄. The issue was the <code>M5.begin</code> call. I was passing <code>true</code> to <code>DisplayEnable</code>, but I guess there is some collision, so the device can't drive the strip and the matrix display at a same time. For my project the strip alone is good enough, so disabling the display is not a problem.</p>
#include "M5Atom.h"
#include "Adafruit_NeoPixel.h"
#define PIN            32
#define NUMPIXELS      10
#define DELAYVAL      500
Adafruit_NeoPixel pixels(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
    M5.begin(true, true, false);
    pixels.setBrightness(255);
    pixels.begin();
    Serial.println("\nGroveLedStickTest\n");
    pixels.clear();
    for (int i = 0; i &lt; NUMPIXELS; i++) {
        pixels.setPixelColor(i, pixels.Color(255, 0, 255));
        pixels.show();
        delay(DELAYVAL);
]]></description><link>https://community.m5stack.com/post/15598</link><guid isPermaLink="true">https://community.m5stack.com/post/15598</guid><dc:creator><![CDATA[mnf]]></dc:creator><pubDate>Thu, 25 Nov 2021 12:52:46 GMT</pubDate></item><item><title><![CDATA[Reply to Using Grove - RGB LED Stick with ATOM Matrix? on Thu, 25 Nov 2021 10:19:19 GMT]]></title><description><![CDATA[<p dir="auto">You should be able to use it as a RGB Unit but you may need to define a custom port just to flip which IOpins to use.<img src="/assets/uploads/files/1637835368570-screenshot-2021-11-25-at-10.15.57.png" alt="0_1637835366836_Screenshot 2021-11-25 at 10.15.57.png" class=" img-fluid img-markdown" /><br />
by default the pins are set as 33/32 and so if you select custom port you can try setting them to 32/33 (flipping the defined IO pins around.<br />
<img src="/assets/uploads/files/1637835470655-screenshot-2021-11-25-at-10.17.41.png" alt="0_1637835469165_Screenshot 2021-11-25 at 10.17.41.png" class=" img-fluid img-markdown" /></p>
<p dir="auto"><strong>Opps that should be 32 and 26 changing to 26 and 32, Sorry!</strong></p>
]]></description><link>https://community.m5stack.com/post/15597</link><guid isPermaLink="true">https://community.m5stack.com/post/15597</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 25 Nov 2021 10:19:19 GMT</pubDate></item><item><title><![CDATA[Reply to Using Grove - RGB LED Stick with ATOM Matrix? on Wed, 24 Nov 2021 19:05:33 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/mnf" aria-label="Profile: mnf">@<bdi>mnf</bdi></a></p>
<p dir="auto">have you tried the <a href="https://github.com/m5stack/M5Atom/tree/master/examples/Basics/LEDDisplay" target="_blank" rel="noopener noreferrer nofollow ugc">stock example</a> driving the 25 built-in LEDs? If that works, find where the GPIO is defined for the built-in LEDs (e.g. GPIO27) and change that to the GPIO used for the external LEDs (e.g. GPIO32). (Don't forget to change the number of LEDs from 25 to 10.)</p>
<p dir="auto">BTW: These LEDs are controlled with one single line (clock and data combined) whereas I2C uses two lines (one for clock and one for data). That is the reason the I2C scanner didn't find anything in addition to 0x68 (built in IMU) with the LED Stick attached.</p>
]]></description><link>https://community.m5stack.com/post/15589</link><guid isPermaLink="true">https://community.m5stack.com/post/15589</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 24 Nov 2021 19:05:33 GMT</pubDate></item></channel></rss>
