<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[External Power - What is possible?]]></title><description><![CDATA[<p dir="auto">Hi @all,<br />
we have now 2 projects which need external power supply for the M5. So maybe someone here can explain what kind of possibilities we have. I can think about the following:</p>
<li>Connect an external 1S LiPo/LiIon battery to the Battery / VBat connector pin (2x15 header).</li>
<li>Connect regulated ~4 Volts to the VBat Connector pin. Could be used when there is no 3,3V or 5V available.</li>
<li>Connect 5V to the 5V Connector pin.</li>
<li>Connect 3,3V to the 3,3V Connector pin.</li>
<p dir="auto">Can anybody here give some comments about the ideas? I don't think all will properly work!?<br />
And maybe there are other solutions I missed?</p>
<p dir="auto">And btw. what are the HPWR pins for? It sounds like high power external source. But I can't find any information.</p>
<p dir="auto"><em>Update</em><br />
I forget to the point with USB power ... How will the above ideas behave if you insert the USB connector?</p>
<p dir="auto">regards<br />
Dominik</p>
]]></description><link>https://community.m5stack.com/topic/377/external-power-what-is-possible</link><generator>RSS for Node</generator><lastBuildDate>Thu, 30 Apr 2026 16:41:07 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/377.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 23 Oct 2018 05:49:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to External Power - What is possible? on Sun, 24 Mar 2019 15:19:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/b1063n" aria-label="Profile: b1063n">@<bdi>b1063n</bdi></a> said in <a href="/post/3410">External Power - What is possible?</a>:</p>
<p dir="auto">So, did anyone find a solution. I was about to buy it, but then when I look at the documentation for the power supply voltage I cannot find it! Documentation is quite poor I must add.</p>
<p dir="auto">I do not need battery operated solution, and the USB power is super ugly and inconvenient!</p>
<p dir="auto">I need to use external 5V power supply connected to pins inside the board in a professional manner (no pcb hacking). Is this not possible? I cannot believe it!!</p>
<p dir="auto">Yes it is possible as the Stackable modules provide internal power to M5Stack cores. (Sorry been working on my books and documenting units with demos this weekend.)</p>
<p dir="auto">The documents I have, show that each stackable module has its own voltage regulator that delivers 5 volts to pin 28 of the internal bus (+5V).<br />
If you look at the Proto module you will see that these pins are marked ready for you.<br />
<a href="https://docs.m5stack.com/#/en/module/proto" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/#/en/module/proto</a></p>
]]></description><link>https://community.m5stack.com/post/3411</link><guid isPermaLink="true">https://community.m5stack.com/post/3411</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 24 Mar 2019 15:19:50 GMT</pubDate></item><item><title><![CDATA[Reply to External Power - What is possible? on Sun, 24 Mar 2019 14:05:38 GMT]]></title><description><![CDATA[<p dir="auto">So, did anyone find a solution. I was about to buy it, but then when I look at the documentation for the power supply voltage I cannot find it! Documentation is quite poor I must add.</p>
]]></description><link>https://community.m5stack.com/post/3410</link><guid isPermaLink="true">https://community.m5stack.com/post/3410</guid><dc:creator><![CDATA[b1063n]]></dc:creator><pubDate>Sun, 24 Mar 2019 14:05:38 GMT</pubDate></item><item><title><![CDATA[Reply to External Power - What is possible? on Thu, 25 Oct 2018 09:33:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/moelski" aria-label="Profile: moelski">@<bdi>moelski</bdi></a> 在 <a href="/post/1833">External Power - What is possible?</a> 中说：</p>
<p dir="auto">I would assume that the IP5306 has an internal protection for reverse current.</p>
<p dir="auto">It is not specified in the IP5306 datasheet.<br />
You can test it and report the results.</p>
]]></description><link>https://community.m5stack.com/post/1837</link><guid isPermaLink="true">https://community.m5stack.com/post/1837</guid><dc:creator><![CDATA[loboris]]></dc:creator><pubDate>Thu, 25 Oct 2018 09:33:46 GMT</pubDate></item><item><title><![CDATA[Reply to External Power - What is possible? on Thu, 25 Oct 2018 07:25:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> 在 <a href="/post/1834">External Power - What is possible?</a> 中说：</p>
<p dir="auto">You are aware that there are 2 battery connection on the M5?<br />
1 is in the 2x15 connection, one is on the actual main pcb.</p>
<p dir="auto">Yes I saw that. I think that both directly connected to the VBat connection, correct?!<br />
<img src="/assets/uploads/files/1540452267540-vbat-connect.png" alt="0_1540452267316_VBAt Connect.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/1835</link><guid isPermaLink="true">https://community.m5stack.com/post/1835</guid><dc:creator><![CDATA[moelski]]></dc:creator><pubDate>Thu, 25 Oct 2018 07:25:15 GMT</pubDate></item><item><title><![CDATA[Reply to External Power - What is possible? on Thu, 25 Oct 2018 06:14:33 GMT]]></title><description><![CDATA[<p dir="auto">You are aware that there are 2 battery connection on the M5?<br />
]]></description><link>https://community.m5stack.com/post/1834</link><guid isPermaLink="true">https://community.m5stack.com/post/1834</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 25 Oct 2018 06:14:33 GMT</pubDate></item><item><title><![CDATA[Reply to External Power - What is possible? on Thu, 25 Oct 2018 03:41:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/loboris" aria-label="Profile: loboris">@<bdi>loboris</bdi></a> 在 <a href="/post/1831">External Power - What is possible?</a> 中说：</p>
<p dir="auto">5V connection on the 2x15 connector is the output from IP5306 VOUT pin</p>
<p dir="auto">Well if there is no battery connected and no USB cable attached ... Why should this be a problem?<br />
]]></description><link>https://community.m5stack.com/post/1833</link><guid isPermaLink="true">https://community.m5stack.com/post/1833</guid><dc:creator><![CDATA[moelski]]></dc:creator><pubDate>Thu, 25 Oct 2018 03:41:45 GMT</pubDate></item><item><title><![CDATA[Reply to External Power - What is possible? on Wed, 24 Oct 2018 22:44:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/moelski" aria-label="Profile: moelski">@<bdi>moelski</bdi></a> 在 <a href="/post/1823">External Power - What is possible?</a> 中说：</p>
<p dir="auto">But connecting a 5V source to the 5V connection on the 2x15 connector should be ok, or not?  If there is no battery connected we don need the IP5306?</p>
<p dir="auto">5V connection on the 2x15 connector is the <strong>output</strong> from IP5306 <strong>VOUT</strong> pin (5V Boost output pin), so I don't think it is wise to connect external 5V to it.</p>
]]></description><link>https://community.m5stack.com/post/1831</link><guid isPermaLink="true">https://community.m5stack.com/post/1831</guid><dc:creator><![CDATA[loboris]]></dc:creator><pubDate>Wed, 24 Oct 2018 22:44:14 GMT</pubDate></item><item><title><![CDATA[Reply to External Power - What is possible? on Wed, 24 Oct 2018 12:53:07 GMT]]></title><description><![CDATA[<p dir="auto">Hi,<br />
cutting traces on the PCB is always a bad idea I think ...</p>
<p dir="auto">you should not connect USB cable at the same time the external 5V is connected</p>
<p dir="auto">That's correct but this is a compromise I can live with.</p>
<p dir="auto">regards Dominik</p>
]]></description><link>https://community.m5stack.com/post/1823</link><guid isPermaLink="true">https://community.m5stack.com/post/1823</guid><dc:creator><![CDATA[moelski]]></dc:creator><pubDate>Wed, 24 Oct 2018 12:53:07 GMT</pubDate></item><item><title><![CDATA[Reply to External Power - What is possible? on Wed, 24 Oct 2018 11:46:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/moelski" aria-label="Profile: moelski">@<bdi>moelski</bdi></a> 在 <a href="/post/1807">External Power - What is possible?</a> 中说：</p>
<p dir="auto">It looks very ugly to use a USB Connector</p>
<p dir="auto">If you use external power, some kind of connector must be used.<br />
You could use USB cable with right angle connector, like this one, I don't think it looks <em><strong>ugly</strong></em>.<br />
You can remove the USB-A connector on the other side, and attach whatever power source you have.</p>
<p dir="auto"><img src="http://loboris.eu/ESP32/short-angled-usb-type-c-usb-c-extension-cable-charging-cable.jpg" alt="cable" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/1820</link><guid isPermaLink="true">https://community.m5stack.com/post/1820</guid><dc:creator><![CDATA[loboris]]></dc:creator><pubDate>Wed, 24 Oct 2018 11:46:23 GMT</pubDate></item><item><title><![CDATA[Reply to External Power - What is possible? on Wed, 24 Oct 2018 11:26:26 GMT]]></title><description><![CDATA[<p dir="auto">M5Stack power circuit is designed in a way that you can use only a Li-Po battery (other than USB power) as external power source.<br />
For all other solutions you have to <strong>modify the PCB</strong>.<br />
If you look at the <a href="http://www.m5stack.com/download/M5-Core-Schematic%2820171206%29.pdf" target="_blank" rel="noopener noreferrer nofollow ugc">schematic</a> you can see that the external 5V source could be added at several places, but in all cases you have to cut some PCB traces.<br />
The simplest method should be to attach the external 5V to <em><strong>VIN_USB</strong></em>, no trace cutting is needed, but you should not connect USB cable at the same time the external 5V is connected.</p>
]]></description><link>https://community.m5stack.com/post/1819</link><guid isPermaLink="true">https://community.m5stack.com/post/1819</guid><dc:creator><![CDATA[loboris]]></dc:creator><pubDate>Wed, 24 Oct 2018 11:26:26 GMT</pubDate></item><item><title><![CDATA[Reply to External Power - What is possible? on Wed, 24 Oct 2018 04:03:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/world101" aria-label="Profile: world101">@<bdi>world101</bdi></a> 在 <a href="/post/1813">External Power - What is possible?</a> 中说：</p>
<p dir="auto"><a target="_blank" rel="noopener noreferrer nofollow ugc">m5stack battery module</a>. 850mAh of internal power. If you need more than that, it will have to be custom.</p>
<p dir="auto">Hi !<br />
I know there is a battery pack and I got two of them. But this is not always a solution. There are projects where you can't stack a lot of moduls on top of each other. And as said ... Using USB as power is very ugly and space consuming.</p>
<p dir="auto">If you need more than that, it will have to be custom.</p>
<p dir="auto">Correct. And what I want to know is which custom solutions are available.<br />
Or to be more precise ... Which kind of power solutions are available without using the Battery module or an USB connection and which kind of drawbacks have those solutions?</p>
<p dir="auto">I can't beleave that I'm the only guy how has those "problems".</p>
Dominik</p>
]]></description><link>https://community.m5stack.com/post/1814</link><guid isPermaLink="true">https://community.m5stack.com/post/1814</guid><dc:creator><![CDATA[moelski]]></dc:creator><pubDate>Wed, 24 Oct 2018 04:03:58 GMT</pubDate></item><item><title><![CDATA[Reply to External Power - What is possible? on Wed, 24 Oct 2018 01:05:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/moelski" aria-label="Profile: moelski">@<bdi>moelski</bdi></a> 在 <a href="/post/1807">External Power - What is possible?</a> 中说：</p>
<p dir="auto">So there must be any suiteable solution to power the M5 from the 2x15 connector. Or somewhere else inside the M5 Stack.</p>
<p dir="auto">There is. It’s called the<br />
]]></description><link>https://community.m5stack.com/post/1813</link><guid isPermaLink="true">https://community.m5stack.com/post/1813</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Wed, 24 Oct 2018 01:05:16 GMT</pubDate></item><item><title><![CDATA[Reply to External Power - What is possible? on Tue, 23 Oct 2018 16:55:57 GMT]]></title><description><![CDATA[<p dir="auto">Hi Holger,<br />
I´m sorry but that is not really an option. It looks very ugly to use a USB Connector. And I don´t wanna use a power bank ...<br />
Dominik</p>
]]></description><link>https://community.m5stack.com/post/1807</link><guid isPermaLink="true">https://community.m5stack.com/post/1807</guid><dc:creator><![CDATA[moelski]]></dc:creator><pubDate>Tue, 23 Oct 2018 16:55:57 GMT</pubDate></item><item><title><![CDATA[Reply to External Power - What is possible? on Tue, 23 Oct 2018 16:33:20 GMT]]></title><description><![CDATA[<p dir="auto">Hello Dominik,<br />
you can use a powerbank with 5VDC USB-Port and connect it to the USB-Port of the M5Stack.<br />
You don't need 3,3VDC because the M5Stack makes it own 3,3V from the 5V Power.<br />
regards Holger</p>
]]></description><link>https://community.m5stack.com/post/1805</link><guid isPermaLink="true">https://community.m5stack.com/post/1805</guid><dc:creator><![CDATA[HOW]]></dc:creator><pubDate>Tue, 23 Oct 2018 16:33:20 GMT</pubDate></item></channel></rss>
