<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Load images on M5Paper in UIFlow]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I'm trying to load images in a M5Paper unit using uiflow with no success. I've tried several formats (png, bmp, jpg) and different options when saving, but I always get the same result...</p>
<p dir="auto">I'm uploading the image in the device file manager, and then after adding the image at the position where I want it, I add the following blocks:</p>
<li>Set screen background color</li>
<li>Set image0 to image.bmp (to the right name of the image file)</li>
<li>Show image0</li>
<li>Set screen show</li>
<p dir="auto">But When running the program, I get an exclamation mark at the top of the screen.</p>
<p dir="auto">Am I doing anything wrong? Is this feature actually working?</p>
]]></description><link>https://community.m5stack.com/topic/3777/load-images-on-m5paper-in-uiflow</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 00:35:24 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3777.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 25 Nov 2021 18:46:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Load images on M5Paper in UIFlow on Mon, 10 Jul 2023 11:07:16 GMT]]></title><description><![CDATA[<p dir="auto">I just got my M5Paper today, so this is very timely info for me, thanks!</p>
]]></description><link>https://community.m5stack.com/post/21537</link><guid isPermaLink="true">https://community.m5stack.com/post/21537</guid><dc:creator><![CDATA[mtylerjr]]></dc:creator><pubDate>Mon, 10 Jul 2023 11:07:16 GMT</pubDate></item><item><title><![CDATA[Reply to Load images on M5Paper in UIFlow on Mon, 10 Jul 2023 05:28:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fr3nd" aria-label="Profile: fr3nd">@<bdi>fr3nd</bdi></a> the picture must be less than 50kb</p>
]]></description><link>https://community.m5stack.com/post/21536</link><guid isPermaLink="true">https://community.m5stack.com/post/21536</guid><dc:creator><![CDATA[Xiong_M5Stack]]></dc:creator><pubDate>Mon, 10 Jul 2023 05:28:54 GMT</pubDate></item><item><title><![CDATA[Reply to Load images on M5Paper in UIFlow on Mon, 26 Jun 2023 08:04:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/7ames" aria-label="Profile: 7ames">@<bdi>7ames</bdi></a> I have used GIMP since 1999 and used it in my guide document. Glad you worked it out.</p>
]]></description><link>https://community.m5stack.com/post/21334</link><guid isPermaLink="true">https://community.m5stack.com/post/21334</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 26 Jun 2023 08:04:45 GMT</pubDate></item><item><title><![CDATA[Reply to Load images on M5Paper in UIFlow on Sun, 25 Jun 2023 11:42:07 GMT]]></title><description><![CDATA[<p dir="auto">I know this is an older thread but it really saved me! I downloaded GIMP (latest version is currently 2.10.34) and by exporting a PNG, Turning all checks off and compression level to 9 (max) and then pixelformat to 8bpc RGB. With a small filename the image will appear in the UI Flow workspace and on the M5 stick C Plus.</p>
<p dir="auto">I couldnt get Photoshop, Aseprite and even Paint to get anything in UI flow. But GIMP worked just fine.<br />
Hope this helps someone else down the road.</p>
]]></description><link>https://community.m5stack.com/post/21326</link><guid isPermaLink="true">https://community.m5stack.com/post/21326</guid><dc:creator><![CDATA[7ames]]></dc:creator><pubDate>Sun, 25 Jun 2023 11:42:07 GMT</pubDate></item><item><title><![CDATA[Reply to Load images on M5Paper in UIFlow on Fri, 15 Apr 2022 19:01:16 GMT]]></title><description><![CDATA[<p dir="auto">This is a limit of the filesystem formatting.</p>
]]></description><link>https://community.m5stack.com/post/17189</link><guid isPermaLink="true">https://community.m5stack.com/post/17189</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 15 Apr 2022 19:01:16 GMT</pubDate></item><item><title><![CDATA[Reply to Load images on M5Paper in UIFlow on Fri, 15 Apr 2022 18:08:15 GMT]]></title><description><![CDATA[<p dir="auto">This is a bit late, but today I was trying to display images in M5Stack Fire module, and had the same problem. After a bit of trial and error, I discovered that if the PNG file names are long, this error will trigger. And it is not easy to guess that the long file name caused it!</p>
]]></description><link>https://community.m5stack.com/post/17188</link><guid isPermaLink="true">https://community.m5stack.com/post/17188</guid><dc:creator><![CDATA[doragasu]]></dc:creator><pubDate>Fri, 15 Apr 2022 18:08:15 GMT</pubDate></item><item><title><![CDATA[Reply to Load images on M5Paper in UIFlow on Sat, 27 Nov 2021 15:34:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fr3nd" aria-label="Profile: fr3nd">@<bdi>fr3nd</bdi></a> I was just about to say that it is an issue with the way the image is saved.<br />
I started making a document here :<a href="https://github.com/Ajb2k3/UIFlowHandbook/blob/master/En-Coreink-V2.pdf" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/Ajb2k3/UIFlowHandbook/blob/master/En-Coreink-V2.pdf</a></p>
]]></description><link>https://community.m5stack.com/post/15631</link><guid isPermaLink="true">https://community.m5stack.com/post/15631</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 27 Nov 2021 15:34:31 GMT</pubDate></item><item><title><![CDATA[Reply to Load images on M5Paper in UIFlow on Sat, 27 Nov 2021 09:40:12 GMT]]></title><description><![CDATA[<p dir="auto">For the record, I was finally able to generate images that load properly with the following ImageMagick command:<br />
<code>convert image.png -colorspace RGB -depth 8 -colors 16 PNG8:exported/image.png</code></p>
]]></description><link>https://community.m5stack.com/post/15629</link><guid isPermaLink="true">https://community.m5stack.com/post/15629</guid><dc:creator><![CDATA[fr3nd]]></dc:creator><pubDate>Sat, 27 Nov 2021 09:40:12 GMT</pubDate></item><item><title><![CDATA[Reply to Load images on M5Paper in UIFlow on Fri, 26 Nov 2021 09:56:12 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/fr3nd" aria-label="Profile: fr3nd">@<bdi>fr3nd</bdi></a></p>
<p dir="auto">sorry, I don't know of any documentation on the requirements of the images.</p>
]]></description><link>https://community.m5stack.com/post/15613</link><guid isPermaLink="true">https://community.m5stack.com/post/15613</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 26 Nov 2021 09:56:12 GMT</pubDate></item><item><title><![CDATA[Reply to Load images on M5Paper in UIFlow on Fri, 26 Nov 2021 08:32:55 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a></p>
<p dir="auto">This works with the default image <code>default.png</code>, but once I upload a different one it shows the exclamation mark symbol.</p>
<p dir="auto">I've tried with different formats and options when saving, but I haven't found a combination that works. Is there any documentation on the requirements of the images? Has anyone had any success using custom images in m5paper in uiflow?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://community.m5stack.com/post/15612</link><guid isPermaLink="true">https://community.m5stack.com/post/15612</guid><dc:creator><![CDATA[fr3nd]]></dc:creator><pubDate>Fri, 26 Nov 2021 08:32:55 GMT</pubDate></item><item><title><![CDATA[Reply to Load images on M5Paper in UIFlow on Thu, 25 Nov 2021 21:49:22 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/fr3nd" aria-label="Profile: fr3nd">@<bdi>fr3nd</bdi></a></p>
<p dir="auto">have you tried to display the <code>default.jpg</code>? Does that work?</p>
<p dir="auto">Using UIFlow 1.8.7 (<a href="https://flow.m5stack.com" target="_blank" rel="noopener noreferrer nofollow ugc">https://flow.m5stack.com</a>) these are the steps which worked for me:</p>
<li>drag image icon onto screen (e.g. image0)</li>
<li>block <code>set image0 image default.jpg</code></li>
<li>block <code>set screen show</code></li>
]]></description><link>https://community.m5stack.com/post/15605</link><guid isPermaLink="true">https://community.m5stack.com/post/15605</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 25 Nov 2021 21:49:22 GMT</pubDate></item></channel></rss>
