<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[2Relay pin out?]]></title><description><![CDATA[<p dir="auto">Hi Guys, just got my 2Relays just wandering what is pin c on the relay . Why and how to use it. Dave</p>
]]></description><link>https://community.m5stack.com/topic/3805/2relay-pin-out</link><generator>RSS for Node</generator><lastBuildDate>Fri, 01 May 2026 14:31:24 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3805.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 06 Dec 2021 09:28:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 2Relay pin out? on Mon, 06 Dec 2021 10:30:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> Thanks</p>
]]></description><link>https://community.m5stack.com/post/15732</link><guid isPermaLink="true">https://community.m5stack.com/post/15732</guid><dc:creator><![CDATA[Devan]]></dc:creator><pubDate>Mon, 06 Dec 2021 10:30:27 GMT</pubDate></item><item><title><![CDATA[Reply to 2Relay pin out? on Mon, 06 Dec 2021 09:42:12 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/devan" aria-label="Profile: Devan">@<bdi>Devan</bdi></a></p>
<p dir="auto">I'd say using the C pin is optional. From the drawing you can see that the two C pins are just connected to each other internally. So to connect and switch a load you have two options:</p>
<li>use both C pins: connect pin A and C to your power source and connect B and C to your load.</li>
<li>do not use C pins: connect one wire of your power source to pin A, connect one wire of your load to pin B and use a direct connection from your power source to your load for the return wire.</li>
]]></description><link>https://community.m5stack.com/post/15731</link><guid isPermaLink="true">https://community.m5stack.com/post/15731</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Mon, 06 Dec 2021 09:42:12 GMT</pubDate></item></channel></rss>
