<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Stack GPS module (M003) finds no satellites]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I have bought two M5Stack GPS modules. Finally I only want to use the PPS signals, but even with the external antenna the PPS output (directly at pin 3 of the NEO-M8N chip) does not work. When I connect the module to Core 2 I am able to communicate (through port 14/13) with the modules, but it is not able to find any satellite. For the test I used UIFlow V1.8.8-core2 and an Arduino sample of the support. I could also verify the communication as it switches to INVALID for the satellites without GPS module connected to Core2. For the test I used the internal and the external antenna (of course I changed the internal connection each time), also outside the building with free view on sky. Has anyone of you an idea, why it does not work? It would be quite strange having received two defect modules by a well-known European distributor.</p>
<p dir="auto">Thanks, Dennis</p>
]]></description><link>https://community.m5stack.com/topic/3809/m5stack-gps-module-m003-finds-no-satellites</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 00:38:25 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3809.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 07 Dec 2021 10:02:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Stack GPS module (M003) finds no satellites on Mon, 23 Jun 2025 10:03:53 GMT]]></title><description><![CDATA[<p dir="auto">Hey Dennis, sounds like you’ve covered most of the basics. A few things to check: make sure the antenna switch (INT/EXT) is physically set correctly on the module. Also, the NEO-M8N can take a few minutes for a cold start—try leaving it powered outside for 15–20 minutes. Lastly, ensure it has a clean 3.3V power source; voltage drops can affect satellite acquisition. If none of that helps, try updating the GPS firmware via u-center. Two dead modules is unlikely, but not impossible. Good luck!</p>
]]></description><link>https://community.m5stack.com/post/29322</link><guid isPermaLink="true">https://community.m5stack.com/post/29322</guid><dc:creator><![CDATA[hacxx]]></dc:creator><pubDate>Mon, 23 Jun 2025 10:03:53 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack GPS module (M003) finds no satellites on Thu, 21 Mar 2024 11:41:21 GMT]]></title><description><![CDATA[<p dir="auto">Hi the solution is Turning of the PSRAM in tools in the arduino IDE.<br />
Also you need to go outside for signal.<br />
If you have "no gps connection" try to switch the tx and rx pin in the ss.begin()</p>
]]></description><link>https://community.m5stack.com/post/24504</link><guid isPermaLink="true">https://community.m5stack.com/post/24504</guid><dc:creator><![CDATA[mylesdebaerdemaeker]]></dc:creator><pubDate>Thu, 21 Mar 2024 11:41:21 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack GPS module (M003) finds no satellites on Mon, 13 Dec 2021 22:00:05 GMT]]></title><description><![CDATA[<p dir="auto">I have tried quite a lot of things, but the M003 modules did not find any satellites. At least the PPS pulses should be present even without any core connected if the modules are powered with 3.3V. Probably I received two defect devices.</p>
<p dir="auto">Meanwhile I bought two GPS units of type AT6558. They are less expensive and they do now their job without any problem. They have even the advantage of an integrated voltage regulator, so they are not dependant of a power supply with an exactly regulated voltage value.</p>
<p dir="auto">It is just a little bit tricky if one wants to use the pps output of the GPS chip as it is already connected with a blue LED inside the device (not visible if case is closed). So some soldering work has to be done.</p>
]]></description><link>https://community.m5stack.com/post/15810</link><guid isPermaLink="true">https://community.m5stack.com/post/15810</guid><dc:creator><![CDATA[dennis78ac]]></dc:creator><pubDate>Mon, 13 Dec 2021 22:00:05 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack GPS module (M003) finds no satellites on Tue, 07 Dec 2021 22:23:04 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a></p>
<p dir="auto">thank you for your ideas. Nevertheless the M003 module only needs 3.3 V, as both chips (NEO-M8N and M24C32) are working with 3.3 V. Nevertheless I enabled also the internal 5-V-bus and I verified at the bus with a multimeter that both voltages are present (see also schematic <a href="https://docs.m5stack.com/en/module/gps#schematic" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/en/module/gps#schematic</a>) ... and even if I switch to external power supply with the help of LAN module W5500 I have the same result. Unfortunetely I have only the Core2 base and not another core for testing.</p>
<p dir="auto">Greetings, Dennis</p>
]]></description><link>https://community.m5stack.com/post/15753</link><guid isPermaLink="true">https://community.m5stack.com/post/15753</guid><dc:creator><![CDATA[dennis78ac]]></dc:creator><pubDate>Tue, 07 Dec 2021 22:23:04 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack GPS module (M003) finds no satellites on Tue, 07 Dec 2021 20:09:02 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/dennis78ac" aria-label="Profile: dennis78ac">@<bdi>dennis78ac</bdi></a></p>
<p dir="auto">I wonder if maybe there is a power issue?</p>
<p dir="auto">There is another GPS module (<a href="https://docs.m5stack.com/en/module/comx_gps" target="_blank" rel="noopener noreferrer nofollow ugc">COMX.GPS / M031-G</a>) and for that module M5Stack engineers suggest to use external DC power if used with M5Core2.</p>
<p dir="auto"><em>When used with Core2 series main control, due to the different order of the base pin array, COM.X base pins TX(16), RX(17) correspond to the actual pins TX(14), RX of the Core2 main control (13) <strong>The equipment needs to use external DC for power supply.</strong></em></p>
<p dir="auto"><em>Note: When using the CORE2 or CORE2-FOR-AWS main control to drive the module, please use the DC power input of the base and set the power mode to input mode (refer to the code below), otherwise it will not start normally</em></p>
<p dir="auto">Do you happen to have an M5Stack (Base, Gray, Go)? If yes, does the GPS module work with it?</p>
]]></description><link>https://community.m5stack.com/post/15747</link><guid isPermaLink="true">https://community.m5stack.com/post/15747</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Tue, 07 Dec 2021 20:09:02 GMT</pubDate></item></channel></rss>
