<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[I can&#x27;t use ATOM GPS Kit]]></title><description><![CDATA[<p dir="auto">Hello there, thank you for reading.</p>
<p dir="auto">I live in Japan.<br />
I want to use M5Atom GPS kit to record GPS information.<br />
But it doesn't work at all.<br />
When I write the following code into the GPS kit, it always outputs 0.<br />
<a href="https://github.com/m5stack/M5-ProductExampleCodes/tree/master/AtomBase/AtomicGPS" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5-ProductExampleCodes/tree/master/AtomBase/AtomicGPS</a></p>
<p dir="auto">SD card recording ↓</p>
<pre><code>0.00, 0.00,
0.00, 0.00, 0.00,
0.00, 0.00, 0.00,
0.00, 0.00, 0.00,
0.00, 0.00,
0.00, 0.00,
0.00, 0.00,
0.00, 0.00,
0.00, 0.00,
0.00, 0.00,
0.00, 0.00,
0.00, 0.00,
0.00, 0.00,
0.00, 0.00,
0.00, 0.00,
0.00, 0.00,
0.00, 0.00,
0.00, 0.00,
0.00, 0.00,
0.00, 0.00,
0.00, 0.00,
0.00, 0.00,
0.00, 0.00,
0.00, 0.00,
0.00, 0.00,
0.00, 0.00,
0.00, 0.00,
0.00, 0.00,
0.00, 0.00,
0.00, 0.00,
0.00, 0.00,
0.00, 0.00,
0.00, 0.00,
0.00, 0.00,
0.00, 0.00,
<p dir="auto">What should I do?</p>
]]></description><link>https://community.m5stack.com/topic/3811/i-can-t-use-atom-gps-kit</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 05:31:46 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3811.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 07 Dec 2021 15:41:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to I can&#x27;t use ATOM GPS Kit on Wed, 08 Dec 2021 00:48:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a><br />
thanks Felix!</p>
<p dir="auto">i did’t care about time.<br />
i'm tring to wait few minutes!</p>
]]></description><link>https://community.m5stack.com/post/15755</link><guid isPermaLink="true">https://community.m5stack.com/post/15755</guid><dc:creator><![CDATA[Kei]]></dc:creator><pubDate>Wed, 08 Dec 2021 00:48:42 GMT</pubDate></item><item><title><![CDATA[Reply to I can&#x27;t use ATOM GPS Kit on Tue, 07 Dec 2021 18:48:38 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/kei" aria-label="Profile: Kei">@<bdi>Kei</bdi></a></p>
<p dir="auto">how long did you wait? Do you get all zeros in the debug output as well?</p>
<p dir="auto">When I haven't used my M5Atom GPS kit for a while it takes a couple of 10 minutes for it to get valid data. It also helps being closer to the window or outside.</p>
]]></description><link>https://community.m5stack.com/post/15746</link><guid isPermaLink="true">https://community.m5stack.com/post/15746</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Tue, 07 Dec 2021 18:48:38 GMT</pubDate></item></channel></rss>
