<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5 atom lite connector.]]></title><description><![CDATA[<p dir="auto">All the available info says ph2.0-4p but that is not the correct connector... I think it's an XHR 2.0-4p... can someone please help me get the right connector?</p>
]]></description><link>https://community.m5stack.com/topic/3824/m5-atom-lite-connector</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 06:31:26 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3824.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 12 Dec 2021 21:59:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5 atom lite connector. on Tue, 28 Dec 2021 12:24:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gallopingsloth" aria-label="Profile: gallopingsloth">@<bdi>gallopingsloth</bdi></a> said in <a href="/post/15967">M5 atom lite connector.</a>:</p>
<p dir="auto">I learned all this the hard way after buying a bunch of now useless PH-2.0 4 pin cables.</p>
<p dir="auto">What do you mean by Useless PH-2.0 4 Pins?</p>
<p dir="auto">Grove cables are fully compatible with M5Stack products and HY connectors are compatible with PH as long as they are 2.0 pin spacings.<br />
the only difference is that some are flat topped, some have locating fins and some have clips. I have a selection of various types and have even modded several including posting a guide and a comparison on the forum of the difference.</p>
<p dir="auto">There was some confusion at one point with the White and yellow wires reversed but that has been solved and its not hard to swap the pins in the housing as again I have made a guide on it.</p>
]]></description><link>https://community.m5stack.com/post/15975</link><guid isPermaLink="true">https://community.m5stack.com/post/15975</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 28 Dec 2021 12:24:44 GMT</pubDate></item><item><title><![CDATA[Reply to M5 atom lite connector. on Tue, 28 Dec 2021 10:50:00 GMT]]></title><description><![CDATA[<p dir="auto">Probably the grove name is property of seedstudio, so m5stack don't use this in description.</p>
]]></description><link>https://community.m5stack.com/post/15971</link><guid isPermaLink="true">https://community.m5stack.com/post/15971</guid><dc:creator><![CDATA[robalstona]]></dc:creator><pubDate>Tue, 28 Dec 2021 10:50:00 GMT</pubDate></item><item><title><![CDATA[Reply to M5 atom lite connector. on Mon, 27 Dec 2021 19:55:17 GMT]]></title><description><![CDATA[<p dir="auto">This is a <em>very</em> frustrating error in the M5Stack documentation package. The <a href="https://docs.m5stack.com/en/core/atom_matrix" target="_blank" rel="noopener noreferrer nofollow ugc">ATOM product page</a> contains conflicting information on this connector.</p>
<p dir="auto">The physical label on the ATOM <strong>incorrectly</strong> describes the connector as a PH 2.0-4P. The product description, under the "Specification" section calls it a GROVE connector.</p>
<p dir="auto">The technically correct description is an DL20005 (HY Series) 4pin connector. Near as I can find the original manufacturer is DLL. Full specs are <a href="http://www.zjdll.com/en/productshow-11-218.html?q=DL20005%20(HY%20Series)" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
<p dir="auto"><a href="https://www.seeedstudio.com" target="_blank" rel="noopener noreferrer nofollow ugc">seeedstudio</a> adopted this connector and integrated it into their product line, giving it the GROVE trade name.</p>
<p dir="auto">So, if you're looking for cables, look for ones marked with GROVE 4 pin or HY 2.0 4pin (female) connectors. Searching the web for HY series cables will produce a few hits, or they can be sourced through <a href="https://www.seeedstudio.com/cables-c-949.html" target="_blank" rel="noopener noreferrer nofollow ugc">seedstudios</a> or <a href="https://shop.m5stack.com/collections/m5-accessories/products/4pin-buckled-grove-cable" target="_blank" rel="noopener noreferrer nofollow ugc">M5Stack</a>.</p>
<p dir="auto">When buying, you'll find "buckled" and "unbuckled" versions. "Buckle" refers to cable connectors either with ("buckled") or without ("unbuckled") a captivating latch. For the the ATOM, both work. For other boards the latch may interfere with their packaging, so you'll need the unbuckled version.</p>
<p dir="auto">Also note that if you're buying cables with connectors on both ends, you might find "standard" and "reversed" pinouts. You'll most likely want the "standard" type, which means pin 1 is connected to pin 1, etc., instead of pin 1 connected to pin 4 ("reversed"). "Standard" is the seeedstudios standard.</p>
<p dir="auto">M5Stack folk, if you monitor the forums, please change the label on the ATOM to say either GROVE or HY 2.0 4P. Please 😄.</p>
<p dir="auto">(Edit: Just noted that the M5StickC PLUS does correctly label this connector as HY2.0-4P. So some M5Stack folk are aware of the difference.)</p>
]]></description><link>https://community.m5stack.com/post/15967</link><guid isPermaLink="true">https://community.m5stack.com/post/15967</guid><dc:creator><![CDATA[GallopingSloth]]></dc:creator><pubDate>Mon, 27 Dec 2021 19:55:17 GMT</pubDate></item><item><title><![CDATA[Reply to M5 atom lite connector. on Mon, 13 Dec 2021 16:49:15 GMT]]></title><description><![CDATA[<p dir="auto">This connector type is used by seeedstudio and they called it <strong>grove</strong></p>
]]></description><link>https://community.m5stack.com/post/15806</link><guid isPermaLink="true">https://community.m5stack.com/post/15806</guid><dc:creator><![CDATA[robalstona]]></dc:creator><pubDate>Mon, 13 Dec 2021 16:49:15 GMT</pubDate></item></channel></rss>
