<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[no current&#x2F;amp reduction with Power save mode for NB-IOT sim7020G in M5 COM.NB-IoT module ?]]></title><description><![CDATA[<p dir="auto">Hi</p>
<p dir="auto">I connect an amp meter between the 5V pin in the M5 module and the 5V supply.<br />
I run the AT command AT+CPSMS=1,,,"01000101","00100010"<br />
I get the message after one minute that power save mode is turned on.<br />
but the current stays on 10mA, no reduction.</p>
<p dir="auto">Anyone see what I am doing wrong ?</p>
<p dir="auto">BR<br />
/T</p>
]]></description><link>https://community.m5stack.com/topic/3830/no-current-amp-reduction-with-power-save-mode-for-nb-iot-sim7020g-in-m5-com-nb-iot-module</link><generator>RSS for Node</generator><lastBuildDate>Fri, 08 May 2026 14:38:42 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3830.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 15 Dec 2021 08:15:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to no current&#x2F;amp reduction with Power save mode for NB-IOT sim7020G in M5 COM.NB-IoT module ? on Wed, 15 Dec 2021 20:13:12 GMT]]></title><description><![CDATA[<p dir="auto">Thanks you for your quick reply and good info !<br />
BR<br />
/T</p>
]]></description><link>https://community.m5stack.com/post/15833</link><guid isPermaLink="true">https://community.m5stack.com/post/15833</guid><dc:creator><![CDATA[tsil]]></dc:creator><pubDate>Wed, 15 Dec 2021 20:13:12 GMT</pubDate></item><item><title><![CDATA[Reply to no current&#x2F;amp reduction with Power save mode for NB-IOT sim7020G in M5 COM.NB-IoT module ? on Wed, 15 Dec 2021 14:23:21 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/tsil" aria-label="Profile: tsil">@<bdi>tsil</bdi></a></p>
<p dir="auto">can I use some other pin on the M5 COM.NB-IoT module ...</p>
<p dir="auto">not that I know of.</p>
<p dir="auto">Note: most M5Stack devices, modules, units, etc. hardware designs are quite bad when it comes to power saving. Mostly the culprit is the power regulator which by itself uses quite some energy even when the load is very low.</p>
<p dir="auto">Note: there are some M5Stack devices (e.g. M5Paper) which allow the system to fully shutdown and only keep the RTC running. These systems can achieve some level of power saving.</p>
]]></description><link>https://community.m5stack.com/post/15832</link><guid isPermaLink="true">https://community.m5stack.com/post/15832</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 15 Dec 2021 14:23:21 GMT</pubDate></item><item><title><![CDATA[Reply to no current&#x2F;amp reduction with Power save mode for NB-IOT sim7020G in M5 COM.NB-IoT module ? on Wed, 15 Dec 2021 10:43:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a></p>
<p dir="auto">Ok, so there is no power saving when I use the 5 V pin, can I use some other pin on the M5 COM.NB-IoT module to be able to achieve power savings when using PSM or eDRX ?</p>
/T</p>
]]></description><link>https://community.m5stack.com/post/15830</link><guid isPermaLink="true">https://community.m5stack.com/post/15830</guid><dc:creator><![CDATA[tsil]]></dc:creator><pubDate>Wed, 15 Dec 2021 10:43:02 GMT</pubDate></item><item><title><![CDATA[Reply to no current&#x2F;amp reduction with Power save mode for NB-IOT sim7020G in M5 COM.NB-IoT module ? on Wed, 15 Dec 2021 09:24:50 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/tsil" aria-label="Profile: tsil">@<bdi>tsil</bdi></a></p>
<p dir="auto">on the green board there is an additional DC-DC converter which most likely takes about the same amount of current whether the SIM7020G module is in power save mode or not.</p>
<p dir="auto">I guess you'd need to cut the power trace, on the green board, that comes from that DC-DC converter and goes into the SIM7020G module and measure the current there.</p>
]]></description><link>https://community.m5stack.com/post/15828</link><guid isPermaLink="true">https://community.m5stack.com/post/15828</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 15 Dec 2021 09:24:50 GMT</pubDate></item></channel></rss>
