<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Unit : LoRaWAN868 direct message]]></title><description><![CDATA[<p dir="auto">Hello to all,</p>
<p dir="auto">I have just taken two LoraWan868 units in order to test a little the lora.</p>
<p dir="auto">Did one of you already tried and succeeded to send a message between two m5 with connected each one to one of these modules?</p>
<p dir="auto">Would you possibly have a piece of code to propose to me?</p>
<p dir="auto">In advance, I thank you for your answers and your possible help.</p>
]]></description><link>https://community.m5stack.com/topic/3833/unit-lorawan868-direct-message</link><generator>RSS for Node</generator><lastBuildDate>Wed, 06 May 2026 14:09:24 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3833.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 17 Dec 2021 07:39:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Unit : LoRaWAN868 direct message on Fri, 17 Dec 2021 08:25:16 GMT]]></title><description><![CDATA[<p dir="auto">Too bad,</p>
<p dir="auto">Thanks for the answer.</p>
<p dir="auto">Apparently there is no lora point to point gateway in the range? or I did not find it.</p>
<p dir="auto">Thanks again for the time spent on the answer.</p>
]]></description><link>https://community.m5stack.com/post/15844</link><guid isPermaLink="true">https://community.m5stack.com/post/15844</guid><dc:creator><![CDATA[cedricscha]]></dc:creator><pubDate>Fri, 17 Dec 2021 08:25:16 GMT</pubDate></item><item><title><![CDATA[Reply to Unit : LoRaWAN868 direct message on Fri, 17 Dec 2021 08:02:29 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/cedricscha" aria-label="Profile: cedricscha">@<bdi>cedricscha</bdi></a></p>
<p dir="auto">Lora point to point communication is most likely not possible with LoraWan868 units. These units can only do LoraWan and are meant to connect to some cloud service like TTN.</p>
<p dir="auto">Please checkout this <a href="https://community.m5stack.com/topic/3746/lora-module-asr6501-with-arduino">thread</a>.</p>
]]></description><link>https://community.m5stack.com/post/15843</link><guid isPermaLink="true">https://community.m5stack.com/post/15843</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 17 Dec 2021 08:02:29 GMT</pubDate></item></channel></rss>
